I have a problem running the Qt camera example on the Freescale MCIMX6Q-SDP evaluation board.
I am using imx-3.10.53-1.1.0_ga from git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
I built the image with yocto:
bitbake fsl-image-qt5
This is my local.conf:
BB_NUMBER_THREADS ?= "${@oe.utils.cpu_count()}"
PARALLEL_MAKE ?= "-j ${@oe.utils.cpu_count()}"
MACHINE ??= 'imx6qsabresd'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K"
PACKAGECONFIG_pn-qemu-native = "sdl"
PACKAGECONFIG_pn-nativesdk-qemu = "sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '4'
PARALLEL_MAKE = '-j 4'
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = ""
LICENSE_FLAGS_WHITELIST = "commercial"
IMAGE_INSTALL_append = " \
openssh-sftp-server \
cpufrequtils \
nano \
gstreamer \
gst-meta-video \
gst-fsl-plugin \
gst-plugins-base-app \
gst-plugins-base \
gst-plugins-base-meta \
gst-plugins-good \
gst-plugins-good-rtsp \
gst-plugins-good-udp \
gst-plugins-good-rtpmanager \
gst-plugins-good-rtp \
gst-plugins-good-video4linux2 \
gst-plugins-good-meta \
gst-plugins-bad \
gst-plugins-bad-camerabin2 \
gst-plugins-bad-meta \
gst-plugins-ugly \
gst-plugins-ugly-meta \
gst-plugins-gl \
gst-plugins-gl-meta \
gst-plugins-gl-opengl \
packagegroup-fsl-gstreamer \
packagegroup-fsl-tools-testapps \
packagegroup-fsl-tools-benchmark \
imx-vpu \
imx-test \
qtbase-fonts \
qtbase-plugins \
qtbase-tools \
qtbase-examples \
qtmultimedia \
qtmultimedia-plugins \
qtmultimedia-examples \
qtmultimedia-qmlplugins \
qtsvg \
qtsvg-plugins \
qtsensors \
qtimageformats-plugins \
qtsystems \
qtsystems-tools \
qtsystems-examples \
qtsystems-qmlplugins \
qtscript \
qt3d \
qt3d-examples \
qt3d-qmlplugins \
qt3d-tools \
qtdeclarative \
qtdeclarative-plugins \
qtdeclarative-tools \
qtdeclarative-examples \
qtdeclarative-qmlplugins \
qtgraphicaleffects-qmlplugins \
qtconnectivity-qmlplugins \
qtlocation-plugins \
qtlocation-qmlplugins \
cairo pango fontconfig freetype pulseaudio dbus \
alsa-lib alsa-tools alsa-state alsa-utils-alsaconf fsl-alsa-plugins \
i2c-tools \
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer010"
This is my bblayers.conf:
LCONF_VERSION = "6"
BBPATH = "${TOPDIR}"
BSPDIR := "${@os.path.abspath(os.path.dirname(d.getVar('FILE', True)) + '/../..')}"
BBFILES ?= ""
BBLAYERS = " \
${BSPDIR}/sources/poky/meta \
${BSPDIR}/sources/poky/meta-yocto \
${BSPDIR}/sources/meta-openembedded/meta-oe \
${BSPDIR}/sources/meta-fsl-arm \
${BSPDIR}/sources/meta-fsl-arm-extra \
${BSPDIR}/sources/meta-fsl-demos \
##Freescale Yocto Release layer
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-fsl-arm "
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-fsl-demos "
BBLAYERS += " ${BSPDIR}/sources/meta-browser "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-gnome "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-networking "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-ruby "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-multimedia "
BBLAYERS += " ${BSPDIR}/sources/meta-qt5 "
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-fsl-qt5 "
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-fsl-bluez "
When I run the Qt camera example (/usr/share/qt5/examples/multimediawidgets/camera/camera) I get the following warnings and errors:
Qt Warning: Could not find a location of the system's Compose files. Consider setting the QTCOMPOSE environment variable.
** (camera:1054): CRITICAL **: gst_photography_set_focus_mode: assertion 'photo != NULL' failed
Warning: EGL suggested using X Visual ID 33 (RGB565) for EGL config 1 (RGB444), but this is incompatable
Unable to find an X11 visual which matches EGL config 1
** (camera:1054): CRITICAL **: gst_missing_encoder_message_new: assertion '!gst_caps_is_any (encode_caps)' failed
(camera:1054): GStreamer-CRITICAL **: gst_element_post_message: assertion 'message != NULL' failed
CameraBin error: "Your GStreamer installation is missing a plug-in."
I have tried to put in the image all the gstreamer plugins (base, good, bad, ugly).
I don't understand which plugin is missing.
Any help would be very appreciated.
Thank you very much
I checked the difference between v4l2src and imxv4l2src, v4l2src meas video source, and imxv4l2src means camera source.
it seems this QT application doesn't capture source from camera, did you try to use the latest bsp? because 3.10.53 is old version, if you must use this vesrion, pls let me know it, let me try to install it and reproduce it.
Hi Guanqiong
I use the 3.14.52 BSP.
I have solved the problem in a total different way.
I made a linux service like program that take the frame from the source, the camera, and push the frame to the display.
The same frame pushed to the "appsrc", that way I can use it to record the frames and capture pictures.
I used the unit_test/v4l2... source as my reference for that.
thank you
Hello all,
We are facing the same issue.
I found out that in our system the reason to the memory leak is the ioctl function VIDIOC_ENUMSTD.
The Gstreamer get in to a endless loop because of not valid data from the v4l2 capture driver.
Did someone managed to solve the issue?
We are also facing same issue.
Did you able to get QT camera working?
I have added to local.conf, in IMAGE_INSTALL_append, the package packagegroup-fsl-gstreamer-full.
Adding that package the error has changed; now there is an out of memory error.
** (camera:1080): CRITICAL **: gst_photography_set_focus_mode: assertion 'photo != NULL' failed
camera invoked oom-killer: gfp_mask=0x200da, order=0, oom_score_adj=0
CPU: 1 PID: 1080 Comm: camera Not tainted 3.10.53-1.1.0_ga+g496fbe0 #1
[<80013b00>] (unwind_backtrace+0x0/0xf4) from [<80011524>] (show_stack+0x10/0x14
[<80011524>] (show_stack+0x10/0x14) from [<8067eb98>] (dump_header.isra.10+0x68/
0x188)
[<8067eb98>] (dump_header.isra.10+0x68/0x188) from [<80093288>] (oom_kill_proces
s+0x268/0x3b8)
[<80093288>] (oom_kill_process+0x268/0x3b8) from [<80093850>] (out_of_memory+0x2
ac/0x2d8)
[<80093850>] (out_of_memory+0x2ac/0x2d8) from [<800976fc>] (__alloc_pages_nodema
sk+0x858/0x89c)
[<800976fc>] (__alloc_pages_nodemask+0x858/0x89c) from [<800af574>] (handle_pte_
fault+0x550/0x74c)
[<800af574>] (handle_pte_fault+0x550/0x74c) from [<800af828>] (handle_mm_fault+0
xb8/0x100)
[<800af828>] (handle_mm_fault+0xb8/0x100) from [<8001860c>] (do_page_fault+0x208
/0x390)
[<8001860c>] (do_page_fault+0x208/0x390) from [<80008394>] (do_DataAbort+0x38/0x
98)
[<80008394>] (do_DataAbort+0x38/0x98) from [<8000ddf4>] (__dabt_usr+0x34/0x40)
Exception stack(0xa837bfb0 to 0xa837bff8)
bfa0: 00000419 00000000 00000df1 328ebe00
bfc0: 7611f4dc 328ec210 328ebe00 00000428 7611f50c 00000001 00001208 00000083
bfe0: 00000419 7ea41210 7605f77c 7605eb88 60000010 ffffffff
Mem-info:
DMA per-cpu:
CPU 0: hi: 186, btch: 31 usd: 94
CPU 1: hi: 186, btch: 31 usd: 17
CPU 2: hi: 186, btch: 31 usd: 172
CPU 3: hi: 186, btch: 31 usd: 77
active_anon:210210 inactive_anon:284 isolated_anon:0
active_file:36 inactive_file:0 isolated_file:0
unevictable:0 dirty:0 writeback:0 unstable:0
free:856 slab_reclaimable:827 slab_unreclaimable:2068
mapped:274 shmem:323 pagetables:807 bounce:0
free_cma:0
DMA free:3500kB min:3336kB low:4168kB high:5004kB active_anon:840840kB inactive_
anon:1136kB active_file:108kB inactive_file:196kB unevictable:0kB isolated(anon)
:0kB isolated(file):0kB present:1048576kB managed:697156kB mlocked:0kB dirty:0kB
writeback:0kB mapped:1096kB shmem:1292kB slab_reclaimable:3308kB slab_unreclaim
able:8272kB kernel_stack:1504kB pagetables:3228kB unstable:0kB bounce:0kB free_c
ma:0kB writeback_tmp:0kB pages_scanned:491 all_unreclaimable? yes
lowmem_reserve[]: 0 0 0 0
DMA: 13*4kB (MR) 10*8kB (MR) 3*16kB (R) 4*32kB (R) 0*64kB 1*128kB (R) 0*256kB 0*
512kB 1*1024kB (R) 1*2048kB (R) 0*4096kB 0*8192kB 0*16384kB 0*32768kB = 3508kB
443 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
262144 pages of RAM
1472 free pages
7038 reserved pages
1658 slab pages
264686 pages shared
0 pages swap cached
[ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name
[ 208] 0 208 753 108 6 0 -1000 udevd
[ 329] 0 329 816 148 6 0 -1000 udevd
[ 330] 0 330 750 105 6 0 -1000 udevd
[ 783] 0 783 670 54 5 0 0 S01xserver-
nodm
[ 806] 0 806 758 22 5 0 0 xinit
[ 807] 996 807 734 73 5 0 0 dbus-daemon
[ 809] 0 809 41147 1182 83 0 0 Xorg
[ 811] 0 811 1400 88 6 0 0 connmand
[ 816] 0 816 565 23 4 0 0 dropbear
[ 821] 0 821 1252 38 6 0 0 wpa_supplic
antbefore the out of memory error
[ 824] 999 824 599 47 5 0 0 rpcbind
[ 835] 997 835 486 30 5 0 0 rpc.statd
[ 847] 0 847 549 13 4 0 0 syslogd
[ 850] 0 850 549 16 4 0 0 klogd
[ 856] 998 856 825 50 5 0 0 avahi-daemo
n
[ 857] 998 857 825 45 5 0 0 avahi-daemo
n
[ 868] 0 868 1113 81 6 0 0 ofonod
[ 876] 0 876 974 31 5 0 0 oprofile-se
rver
[ 878] 0 878 779 23 5 0 0 autohdmi
[ 885] 0 885 654 36 5 0 0 rc_mxc.S
[ 886] 0 886 550 14 5 0 0 getty
[ 888] 0 888 750 66 5 0 0 sh
[ 890] 0 890 1649 186 6 0 0 matchbox-wi
ndow
[ 894] 0 894 841 54 5 0 0 dbus-launch
[ 895] 0 895 701 42 5 0 0 dbus-daemon
[ 910] 0 910 656 41 5 0 0 Xsession
[ 919] 0 919 5581 268 15 0 0 connman-app
let
[ 950] 0 950 5918 607 15 0 0 matchbox-de
skto
[ 951] 0 951 5829 405 15 0 0 matchbox-pa
nel
[ 955] 0 955 23716 338 14 0 0 pulseaudio
[ 957] 0 957 1506 70 7 0 0 gconfd-2
[ 958] 0 958 3788 188 11 0 0 settings-da
emon
[ 963] 0 963 4191 185 12 0 0 console-kit
-dae
[ 1027] 0 1027 1427 105 7 0 0 matchbox-ke
yboa
[ 1080] 0 1080 263662 205749 500 0 0 camera
Out of memory: Kill process 1080 (camera) score 780 or sacrifice child
Killed process 1080 (camera) total-vm:1054648kB, anon-rss:822700kB, file-rss:296
kB
Killed
If I run the camera example with strace, I see before the out of memory error a lot of lines like the followig one:
ioctl(16, VIDIOC_ENUMSTD, 0x7ed0b5d0) = 0
It looks like an infinite loop.
Any idea ?
The camera, when used with v4l2, works. For instance the mxc_v4l2_overlay.out unit test works.
The problem is using the camera from Qt.
gst-launch v4l2src ! autovideosink doesn't work (out of memory). This is the output:
Setting pipeline to PAUSED ... | |
MFW_GST_V4LSINK_PLUGIN 4.0.2 build on Mar 2 2015 11:04:36. | |
syslogd invoked oom-killer: gfp_mask=0x201da, order=0, oom_score_adj=0 | |
CPU: 1 PID: 851 Comm: syslogd Not tainted 3.10.53-1.1.0_ga+g496fbe0 #1 |
0x188) |
s+0x268/0x3b8) |
ac/0x2d8) |
sk+0x858/0x89c) |
[<800976fc>] (__alloc_pages_nodemask+0x858/0x89c) from [<800924f8>] (filemap_fau
lt+0x1cc/0x420) |
[<800924f8>] (filemap_fault+0x1cc/0x420) from [<800abedc>] (__do_fault+0x68/0x45
4) |
[<800abedc>] (__do_fault+0x68/0x454) from [<800af094>] (handle_pte_fault+0x70/0x
74c) |
[<800af094>] (handle_pte_fault+0x70/0x74c) from [<800af828>] (handle_mm_fault+0x
b8/0x100) |
/0x390) |
98) | |
Exception stack(0xa8c63fb0 to 0xa8c63ff8) | |
3fa0: | 00000000 76efdffb 76efdf88 000026b0 |
3fc0: 7ef0da58 fbad8001 00000000 76f4d4c0 00000000 000829dc 00000013 7ef0da4c
3fe0: 00000073 7ef0d518 76e25e1c 76e260f8 800f0010 ffffffff | ||
Mem-info: | ||
DMA per-cpu: | ||
CPU | 0: hi: 186, btch: 31 usd: 103 | |
CPU | 1: hi: 186, btch: 31 usd: 176 | |
CPU | 2: hi: 186, btch: 31 usd: 185 | |
CPU | 3: hi: 186, btch: 31 usd: 128 | |
active_anon:210587 inactive_anon:321 isolated_anon:0 | ||
active_file:0 inactive_file:0 isolated_file:0 | ||
unevictable:0 dirty:0 writeback:0 unstable:0 | ||
free:829 slab_reclaimable:770 slab_unreclaimable:2060 | ||
mapped:209 shmem:356 pagetables:722 bounce:0 | ||
free_cma:0 |
DMA free:3316kB min:3336kB low:4168kB high:5004kB active_anon:842348kB inactive_
anon:1284kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB
isolated(file):0kB present:1048576kB managed:697156kB mlocked:0kB dirty:0kB wri
teback:0kB mapped:836kB shmem:1424kB slab_reclaimable:3080kB slab_unreclaimable:
8240kB kernel_stack:1464kB pagetables:2888kB unstable:0kB bounce:0kB free_cma:0k
B writeback_tmp:0kB pages_scanned:561 all_unreclaimable? yes | |
lowmem_reserve[]: 0 0 0 0 |
DMA: 1*4kB (R) 1*8kB (R) 1*16kB (R) 1*32kB (R) 0*64kB 2*128kB (R) 0*256kB 0*512k
B 1*1024kB (R) 1*2048kB (R) 0*4096kB 0*8192kB 0*16384kB 0*32768kB = 3388kB | |||||||
463 total pagecgst-launch imxv4l2src ! imxv4l2sink | |||||||
MFW_GST_V4LSRC_PLUGIN 4.0.2 build on Mar 2 2015 11:04:54. | |||||||
ov5640_download_autofocus: Downloaded firmware successfully: 0 | |||||||
MFW_GST_V4LSINK_PLUGIN 4.0.2 build on Mar 2 2015 11:04:36. | |||||||
Setting pipeline to PAUSED ... | |||||||
Pipeline is live and does not need PREROLL ... | |||||||
Setting pipeline to PLAYING ... | |||||||
New clock: GstSystemClock | |||||||
full screen size:1024x768 | |||||||
[V4L Update Display]: left=0, top=0, width=1024, height=768 | |||||||
set v4l display crop sucessfully | |||||||
set v4l rotate sucessfully | |||||||
>>V4L_SINK: Actually buffer status: | |||||||
hardware buffer : 12 | |||||||
software buffer : 0 | ache pages | ||||||
0 pages in swap cache | |||||||
Swap cache stats: add 0, delete 0, find 0/0 | |||||||
Free swap = 0kB | |||||||
Total swap = 0kB | |||||||
262144 pages of RAM | |||||||
1733 free pages | |||||||
6926 reserved pages | |||||||
1620 slab pages | |||||||
264595 pages shared | |||||||
0 pages swap cached | |||||||
[ pid ] uid tgid total_vm | rss nr_ptes swapents oom_score_adj name | ||||||
[ 208] | 0 208 | 781 | 114 | 5 | 0 | -1000 udevd | |
[ 336] | 0 336 | 749 | 105 | 5 | 0 | -1000 udevd | |
[ 338] | 0 338 | 749 | 102 | 5 | 0 | -1000 udevd | |
[ 787] | 0 787 | 670 | 54 | 4 | 0 | 0 S01xserver- | |
nodm | |||||||
[ 810] 996 810 | 734 | 73 | 5 | 0 | 0 dbus-daemon | ||
[ 812] | 0 812 | 758 | 22 | 5 | 0 | 0 xinit | |
[ 814] | 0 814 | 41099 | 1141 | 84 | 0 | 0 Xorg | |
[ 815] | 0 815 | 1400 | 88 | 6 | 0 | 0 connmand | |
[ 820] | 0 820 | 565 | 23 | 5 | 0 | 0 dropbear | |
[ 825] | 0 825 | 1252 | 38 | 6 | 0 | 0 wpa_supplic | |
ant | |||||||
[ 828] 999 828 | 599 | 45 | 5 | 0 | 0 rpcbind | ||
[ 839] 997 839 | 486 | 30 | 5 | 0 | 0 rpc.statd | ||
[ 851] | 0 851 | 549 | 13 | 5 | 0 | 0 syslogd | |
[ 854] | 0 854 | 549 | 16 | 4 | 0 | 0 klogd | |
[ 860] 998 860 | 825 | 50 | 5 | 0 | 0 avahi-daemo | ||
n | |||||||
[ 861] 998 861 | 825 | 45 | 5 | 0 | 0 avahi-daemo | ||
n | |||||||
[ 872] | 0 872 | 1113 | 80 | 5 | 0 | 0 ofonod | |
[ 880] | 0 880 | 974 | 31 | 6 | 0 | 0 oprofile-se | |
rver | |||||||
[ 882] | 0 882 | 779 | 23 | 5 | 0 | 0 autohdmi | |
[ 888] | 0 888 | 654 | 36 | 5 | 0 | 0 rc_mxc.S | |
[ 889] | 0 889 | 550 | 14 | 5 | 0 | 0 getty | |
[ 891] | 0 891 | 751 | 52 | 4 | 0 | 0 sh | |
[ 894] | 0 894 | 1650 | 187 | 8 | 0 | 0 matchbox-wi | |
ndow | |||||||
[ 898] | 0 898 | 841 | 54 | 4 | 0 | 0 dbus-launch | |
[ 899] | 0 899 | 701 | 42 | 5 | 0 | 0 dbus-daemon | |
[ 914] | 0 914 | 656 | 41 | 5 | 0 | 0 Xsession | |
[ 923] | 0 923 | 5581 | 268 | 14 | 0 | 0 connman-app | |
let | |||||||
[ 954] | 0 954 | 5911 | 608 | 15 | 0 | 0 matchbox-de | |
skto | |||||||
[ 955] | 0 955 | 5829 | 445 | 17 | 0 | 0 matchbox-pa | |
nel | |||||||
[ 957] | 0 957 | 1506 | 70 | 7 | 0 | 0 gconfd-2 | |
[ 959] | 0 959 | 3788 | 188 | 11 | 0 | 0 settings-da | |
emon | |||||||
[ 962] | 0 962 | 23716 | 338 | 14 | 0 | 0 pulseaudio | |
[ 963] | 0 963 | 1427 | 105 | 6 | 0 | 0 matchbox-ke | |
yboa | |||||||
[ 967] | 0 967 | 4191 | 187 | 12 | 0 | 0 console-kit | |
-dae | |||||||
[ 1032] | 0 1032 208419 206144 | 411 | 0 | 0 gst-launch- | |||
0.10 |
Out of memory: Kill process 1032 (gst-launch-0.10) score 781 or sacrifice child
Killed process 1032 (gst-launch-0.10) total-vm:833676kB, anon-rss:824576kB, file
-rss:0kB | |
Killed |
Instead
gst-launch imxv4l2src ! autovideosink works. This is the output: | ||
Both the Qt camera example and "gst-launch v4l2src ! autovideosink" crash in a similar way (out of memory).
On the contrary "gst-launch imxv4l2src ! autovideosink" works.
Maybe the problem is that Qt uses the wrong source plugin, v4l2src instead of imxv4l2src ?
Thank you very much
