Qt Embedded on iMX53 QSB and Zytronic zxy100 touchscreen
Search instead for
GiovanniFoiani
I built a distro for my iMX53 QSB with Yocto with Qt embedded (no X11) and I'd like to use a Zytronic zxy100 touchscreen.
If I set MouseMan driver in QWS_MOUSE_PROTO variable, the input device works fine but obviously it works like a mouse.
I want to use my device as a touchscreen, I read that it's supported by generic usb touchscreen driver but I can't configure Qt to make it work.
Using tslib it doesn't work.
Any idea on how to configure Qt to make it work?
Giovanni
Tags (2)
OtavioSalvador
Senior Contributor II
Did you solve your issue? We might work with you on this if need.
