QT issue in imx8mq evk board os linux 4.14.98 and 5.4.24 demo image
charleshuang
Senior Contributor II
Hi NXP
My customer create QT windows and table.
When he running the test code (untitled), the QT windows will be open in HDMI.
Then he click the table (1), the windows show the motal and feimotal two list item.
Then he try move the window and close windows.
He try to restart the test code (untitled), the windows and list item position is wrong.
Please see the attachment file.
charleshuang
Hi NXP
About the QT issue.  Yocto version is fail.    Ubuntu version is pass.
Why the QT list item position is not match in Yocto?   Please download video and file.
https://drive.google.com/file/d/1qX3PYiDEcdE6nZ_CM8BYnZnpZUPqeADx/view?usp=sharing
QT 錯位issue
Yocto版本是fail . Ubuntu 版本是pass.
請下載影片與檔案且協助確認此問題.'
charleshuang
Hi NXP
Do you have any update about QT issue?
Our customer is just only care the issue about why the "motal" and "feimotal"  list item position is not match.
My customer need to get solution to fixed the issue.
Please update the question .
Thanks.
charleshuang
charleshuang
Hi Joanxie
(1) Run  customer "./untitled" in demo board. (Please download untitled.7z and unzip it)
(2) Click the table, the windows show the motal and feimotal two list item.
(3) Then try to move the window and close windows.
(4) Try to restart the test code (untitled), the windows and list item position is wrong.
Our imx8m demo board is B3 version.
joanxie
what's your demands to test this? do you want to use qt playback video or anything?
charleshuang
Hi NXP
joanxie
it seems this is out of nxp support scope, maybe you can consult from QT
joanxie
what the customer test steps? give me the test steps, let me reproduce this on my board, and what imx8mq do you use? B3 or A1?
