QT/QML 3D applications are not working on the imx8mqevk board
rmani0029
I tried to run the scene 3D QML application on the imx8 platform which has the latest FSL image. When I tried to open the app it was showing the app background only, 3D object rendering was not happening and I checked the journalctl logs, it threw compiled shaders are not okay error continuously. It is the blocking point for me, can you anyone help me how to solve the shaders issues. Please see the attached logs for more details.
Please tell me the backend dependencies for running 3D applications on the imx8mqevk board.
Error logs
etna_draw_vbo:261: compiled shaders are not okay
error: compile failed!
Hi rmani0029
seems gpu open source etnaviv drivers used in the case, they are not supported by nxp,
similar etnaviv issues are widely described on web:
https://github.com/Igalia/meta-webkit/issues/13
http://twoerner.blogspot.com/2017/06/etnavivvivante-update.html
Alternatively one can try nxp demo images from
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
