I'd like to know the propagation delay speed of DDR3 lines in i.MX6Q SABRE-AI layout.
Could you give me blow information?
Layer 1 : propagation delay speed [mil/ps] of DDR3 lines (Single : 50 Ohm, Differential : 100 Ohm).
Layer 3 : propagation delay speed [mil/ps] of DDR3 lines (Single : 50 Ohm, Differential : 100 Ohm).
Keita
Solved! Go to Solution.
I do not have data specific for the Sabre-AI design, sorry.
But hardly results for the Sabre-AI will significantly differ from typical.
Yuri.
You may use typical value of ~150 ps / inch for estimations.
http://www.ultracad.com/mentor/microstrip%20propagation.pdf
https://www.altera.com/en_US/pdfs/literature/an/an224.pdf
Yuri.
Hi Yuri,
Thank you for your reply.
Is it i.MX6Q SABRE-AI's data?
If it is no, do you have information of propagation delay speed [mil/ps]?
Keita
Yuri.
Dear All,
Hello.
Please follow this topic.
Keita
Do you have any information?
Keita
