Program and run XiP with IMXRT1010-EVK
1,076件の閲覧回数
threeboystech
Can someone share a link to the application note or other documentation on how to program the flash on the IMXRT1010-EVK development board.
I have working code running fine when linked to RAM, but I cannot seem to get anything to program or run from flash XiP.
1,053件の閲覧回数
Ramon_Vega
Dear @threeboystech
You can program the flash on the IMXRT1010-EVK by using the Flashloader to program a bootable image into the external memory device either by using Open SDA or MfgTool.
You can find more information on how to do this in these application notes.
AN12108: How to Enable Boot from QSPI Flash – Application Note (nxp.com)
AN12238: i.MX RT Flashloader Use Case – Application Note (nxp.com)
Getting Started with i.MX RT1010 Evaluation Kit | NXP Semiconductors
External memory interfaces for the RT1010:
  • SPI NOR FLASH
  • Single/Dual channel Quad SPI FLASH with XIP support and on-the-fly decryption
  • Octal flash
I hope this information helps!.
Kind Regards.
-Ramon.
1,054件の閲覧回数
Ramon_Vega
Dear @threeboystech
  • SPI NOR FLASH
  • Octal flash
Kind Regards.
-Ramon.
