Problem in booting zImage and dtb in imx6q customized board
5,748件の閲覧回数
sankarsalla
hi ,
currently i am working on oreo 8.0 integration on our customized carrier board with imx6q processor. we changed u-boot to our customized board and it is booting. after we set some environment variables as below
arch=arm
baudrate=115200
board=pcm058
board_name=pcm058
bootcmd=run loadimage; run loadfdt; bootz ${loadaddr} - ${fdt_addr}
bootdelay=3
console=ttymxc1
cpu=armv7
ethact=FEC
ethaddr=50:2d:f4:0c:b8:cd
ethprime=FEC
fdt_addr=0x18000000
fdt_file=imx6q-phytec-pbab01.dtb
fdt_high=0xffffffff
fdtcontroladdr=4f74cb98
image=zImage
initrd_high=0xffffffff
loadaddr=0x12000000
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
mmcargs=console=${console},${baudrate};root=${mmcroot}
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p1 rootwait rw
soc=mx6
stderr=serial
stdin=serial
stdout=serial
vendor=phytec
Environment size: 725/16379 bytes
=> boot
reading zImage
9949440 bytes read in 493 ms (19.2 MiB/s)
reading imx6q-phytec-pbab01.dtb
41911 bytes read in 19 ms (2.1 MiB/s)
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800d3b6
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
hanged.....................
After that it is loading dtb file and it is not loading zImage , can you please help on this, how to solve my issue.
can you please guide me on this.
Anantha
ラベル(3)
7 返答(返信)
4,956件の閲覧回数
sankarsalla
Hi Sir,
Please find the attached log,  After that my board is not booting, could you please help me on this
U-Boot 2017.03-g2537522-dirty (Jul 03 2018 - 15:47:03 +0530)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 37C
Reset cause: POR
Model: Phytec phyCORE-i.MX6 Quad with NAND
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected n25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
Hit any key to stop autoboot: 0
=> run mmcargs
=> boot
reading zImage
11749400 bytes read in 667 ms (16.8 MiB/s)
reading imx6q-phytec-mira-rdk-nand.dtb
51474 bytes read in 19 ms (2.6 MiB/s)
Using Device Tree in place at 18000000, end 1800f911
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.9.17 (ananth@dhoni) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #3 SMP PREEMPT Tue Jul 17 18:45:56 IST 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: Phytec phyBOARD-MIRA Quad Carrier-Board with nand
cma: Reserved 448 MiB at 0x2a000000
Memory policy: Data cache writealloc
percpu: Embedded 15 pages/cpu @f6eb4000 s31040 r8192 d22208 u61440
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260368
Kernel command line: console=ttymxc1,115200 init=/init root=/dev/mmcblk0p2 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxd
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 557376K/1048576K available (12288K kernel code, 1009K rwdata, 4144K rodata, 3072K init, 592K bss, 32448K reserved, 458752K cma-reserved, 139264K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf8000000 - 0xff800000 ( 120 MB)
lowmem : 0xc0000000 - 0xf7800000 ( 888 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1500000 (3072 kB)
.data : 0xc1500000 - 0xc15fc7d8 (1010 kB)
.bss : 0xc15fc7d8 - 0xc1690860 ( 593 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Build-time adjustment of leaf fanout to 32.
NR_IRQS:16 nr_irqs:16 16
L2C-310 errata 752271 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Security Framework initialized
SELinux: Initializing.
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU0: update cpu_capacity 1024
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100058
CPU1: update cpu_capacity 1024
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: update cpu_capacity 1024
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: update cpu_capacity 1024
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
CPU3: update max cpu_capacity 1024
devtmpfs: initialized
CPU2: update max cpu_capacity 1024
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6Q, silicon rev 1.5
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
imx-gpc 20dc000.gpc: Registered imx-gpc
mxs-dma 110000.dma-apbh: initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
stmpe-i2c 0-0044: failed to read regs 0x0: -110
stmpe-i2c: probe of 0-0044 failed with error -110
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA, using PIO instead.
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA, using PIO instead.
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
MIPI CSI2 driver module loaded
imx rpmsg driver is registered.
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.830:1): initialized
workingset: timestamp_bits=30 max_order=18 bucket_order=0
Registering sdcardfs 0.1
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
fuse init (API version 7.26)
bounce: pool size: 64 pages
io scheduler noop registered
imx-weim 21b8000.weim: Driver registered.
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 3.3
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 70, base_baud = 5000000) is a IMX
console [ttymxc1] enabled
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 71, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized
imx-ipuv3 2400000.ipu: IPUv3H probed
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] No driver support for vblank timestamp query.
imx-drm display-subsystem: bound imx-ipuv3-crtc.2 (ops ipu_crtc_ops)
imx-drm display-subsystem: bound imx-ipuv3-crtc.3 (ops ipu_crtc_ops)
imx-drm display-subsystem: bound imx-ipuv3-crtc.6 (ops ipu_crtc_ops)
imx-drm display-subsystem: bound imx-ipuv3-crtc.7 (ops ipu_crtc_ops)
imx-drm display-subsystem: bound display@di0 (ops imx_pd_ops)
dwhdmi-imx 120000.hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
imx-drm display-subsystem: bound 120000.hdmi (ops dw_hdmi_imx_ops)
Console: switching to colour frame buffer device 100x30
imx-drm display-subsystem: fb0: frame buffer device
imx-ipuv3 2800000.ipu: IPUv3H probed
brd: module loaded
loop: module loaded
zram: Added device: zram0
at24 2-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
random: fast init done
nand: device found, Manufacturer ID: 0x01, Chip ID: 0xd3
nand: AMD/Spansion S34ML08G2
nand: 1024 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
gpmi-nand 112000.gpmi-nand: mode:4 ,failed in set feature.
Bad block table found at page 524224, version 0x01
Bad block table found at page 524160, version 0x01
5 ofpart partitions found on MTD device gpmi-nand
Creating 5 MTD partitions on "gpmi-nand":
0x000000000000-0x000000400000 : "barebox"
0x000000400000-0x000000500000 : "barebox-environment"
0x000000500000-0x000000600000 : "oftree"
0x000000600000-0x000000e00000 : "kernel"
0x000000e00000-0x000040000000 : "root"
gpmi-nand 112000.gpmi-nand: driver registered.
m25p80 spi0.0: found n25q128a13, expected m25p80
m25p80 spi0.0: n25q128a13 (16384 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "barebox"
0x000000100000-0x000000120000 : "barebox-environment"
0x000000120000-0x000000140000 : "oftree"
0x000000140000-0x000001000000 : "kernel"
spi_imx 2008000.ecspi: probed
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
flexcan 2090000.flexcan: device registered (reg_base=f828c000, irq=33)
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver kaweth
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver usbtest
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.9.17 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc2
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mxc_vpu 2040000.vpu_fsl: VPU initialized
Galcore version 6.2.2.96445
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SS08G 7.40 GiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 >
caam 2100000.caam: ERA source: CAAMVID.
caam 2100000.caam: AXI pipeline throttling enabled.
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] 26 d8 63 c6 c3 0e d7 a6
platform caam_sm: [0008] 4e 21 80 ea 0a a2 0e 05
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 74 e1 12 f1 01 f4 16 d7
platform caam_sm: [0008] 24 bb 97 af eb 09 a8 c6
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 50 f3 46 b6 72 ac 07 04
platform caam_sm: [0008] 0d 19 0c 43 0d 57 7e 96
platform caam_sm: [0016] 8a 49 b9 98 f1 bc 61 a6
platform caam_sm: [0024] 48 00 e0 36 dc 8e a0 9f
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 63 5a d3 63 1b 56 56 ff
platform caam_sm: [0008] 56 ca 02 5a 76 1c d6 2b
platform caam_sm: [0016] 58 5f c2 e1 77 4a 86 4b
platform caam_sm: [0024] 9f 83 f0 cd 67 ae 68 bb
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 97 be 73 f1 7b b1 db 04
platform caam_sm: [0008] a9 6c bf 6f 1a 74 3b dc
platform caam_sm: [0016] 06 40 82 a5 dd f9 1b a2
platform caam_sm: [0024] 6c 3f d7 7c 19 c4 76 df
platform caam_sm: [0032] 13 2f e9 88 4d 8e 91 ef
platform caam_sm: [0040] a7 28 43 b1 99 8f b1 a5
platform caam_sm: [0048] 7a a7 b1 d0 d6 96 7f 30
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 98 86 4e 29 58 af af a1
platform caam_sm: [0008] ca e4 23 ff b1 d3 b0 2e
platform caam_sm: [0016] 03 71 32 4c d3 52 81 ae
platform caam_sm: [0024] 33 2c 9b 85 47 87 20 8e
platform caam_sm: [0032] 62 5d 6d c4 a3 db fa fd
platform caam_sm: [0040] 83 7d b7 2f 02 0e 64 cd
platform caam_sm: [0048] 4a c7 b4 3d 52 07 6c 33
platform caam_sm: [0056] 9b 30 82 69 69 be 9f 74
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 43 ed 9d 71 be bf d8 ba
platform caam_sm: [0008] b0 51 f8 28 48 65 45 3b
platform caam_sm: [0016] 39 1a 3e b8 62 8c 76 fe
platform caam_sm: [0024] 03 4c 54 03 86 e0 27 c5
platform caam_sm: [0032] 0d b2 77 4a 33 26 06 58
platform caam_sm: [0040] 5c 49 e8 32 55 be 18 d3
platform caam_sm: [0048] 7a 34 c3 23 4e dc ba af
platform caam_sm: [0056] db 8b f3 fb 5f dd 81 4c
platform caam_sm: [0064] b6 1f 92 d0 fa 0f cb a9
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 6d d5 a3 50 2f a0 d1 31
platform caam_sm: [0008] bd 11 63 8d ed e9 74 38
platform caam_sm: [0016] af c7 0c f5 ed a8 f7 2f
platform caam_sm: [0024] 88 3b f0 4b da b1 48 dd
platform caam_sm: [0032] ed d8 31 78 58 fc 92 11
platform caam_sm: [0040] 44 bc f0 71 12 d3 f3 89
platform caam_sm: [0048] a0 4d b5 39 8b 24 95 24
platform caam_sm: [0056] aa 3d b2 78 58 9e 7c 45
platform caam_sm: [0064] 7f d2 be 15 62 d2 1d 2b
platform caam_sm: [0072] f6 ce 62 19 3c 40 f0 aa
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 4d a2 e6 5a 0a 84 d0 72
platform caam_sm: [0008] e2 0e a4 b0 66 30 60 c0
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] ec e8 a3 82 ff 7c c0 e0
platform caam_sm: [0024] a7 dc c4 c7 17 08 6b b1
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ion_parse_dt_heap_common: id 0 type 4 name cma align 1000
ion_parse_dt_heap_common: id 1 type 1 name sys-contig align 1000
ion_parse_dt_heap_common: id 2 type 0 name system align 1000
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
NET: Registered protocol family 26
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
cpu cpu0: regulators not ready, retry
registered taskstats version 1
dhd_module_init in
input: gpio-keys as /devices/soc0/gpio-keys/input/input0
hctosys: unable to open rtc device (rtc0)
usb_otg_vbus: disabling
flexcan1-reg: disabling
lcd_3v3: disabling
VCC_CAM0: disabling
ALSA device list:
No soundcards found.
Warning: unable to open an initial console.
Freeing unused kernel memory: 3072K (c1200000 - c1500000)
init: init first stage started!
init: First stage mount skipped (missing/incompatible fstab in device tree)
init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
init: Loading SELinux policy
SELinux: Permission validate_trans in class security not defined in policy.
SELinux: the above unknown classes and permissions will be denied
audit: type=1403 audit(3.970:2): policy loaded auid=4294967295 ses=4294967295
selinux: SELinux: Loaded policy from /sepolicy
selinux: SELinux: Loaded file_contexts
init: init second stage started!
selinux: SELinux: Loaded property_contexts from /plat_property_contexts & /nonplat_property_contexts.
init: Running restorecon...
selinux: SELinux: Could not stat /dev/block: No such file or directory.
init: waitpid failed: No child processes
init: Couldn't load property file: Unable to open '/system/etc/prop.default': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/prop.default': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/odm/default.prop': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/vendor/default.prop': No such file or directory: No such file or directory
ueventd: ueventd started!
ueventd: Parsing file /ueventd.rc...
ueventd: Parsing file /vendor/ueventd.rc...
ueventd: Unable to open '/vendor/ueventd.rc': No such file or directory
ueventd: Parsing file /odm/ueventd.rc...
ueventd: Unable to open '/odm/ueventd.rc': No such file or directory
ueventd: Parsing file /ueventd.freescale.rc...
ueventd: Coldboot took 0.260649 seconds
keychord: using input dev gpio-keys for fevent
Console: switching to colour dummy device 80x30
watchdogd: watchdogd started (interval 10, margin 20)!
EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p12): recovery complete
EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
EXT4-fs (mmcblk0p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p6): recovery complete
EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: barrier=1
file system registered
using random self ethernet address
using random host ethernet address
zram0: detected capacity change from 0 to 314572800
mkswap: executing /system/bin/mkswap failed: No such file or directory
mkswap: mkswap terminated by exit(255)
Unable to find swap-space signature
audit: type=1400 audit(4.990:3): avc: granted { read } for pid=1 comm="init" name="ttymxc1" dev="tmpfs" ino=6879 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclae
audit: type=1400 audit(5.010:4): avc: granted { read open } for pid=1 comm="init" path="/dev/ttymxc1" dev="tmpfs" ino=6879 scontext=u:r:init:s0 tcontext=u:object_r:tty_devie
read descriptors
read strings
random: crng init done
Anantha
4,956件の閲覧回数
Hi sankar
one can try with nxp i.MX6Q Sabre reference boards using
Manufacturing Toolkit and VivanteVTK for Android O8.1.0_1.3.0 8MQ GA
https://www.nxp.com/webapp/Download?colCode=O8.1.0_1.3.0_ANDROID_TOOL_8MQ_GA&appType=license&locatio...
The same procedure (as described in ucl2.xml file) can be used for other boards, like phytec.
Note, images should be built from phytec repository.
More NXP Android documentation can be found on :
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
4,956件の閲覧回数
sankarsalla
hi,
after loading kernel it is trying to run all the services from vendor folder, but i dont have any hardware connected like wifi and gsm, i have connected only lcd, it is continuously running services and board not booting fully, how to resolve this issue, my log is attached belw, could you please help me on this
regards,
anantha
4,956件の閲覧回数
seems it is necessary to rebuld mfg tools firmware removing unused drivers.
The recipes used to build a manufacturing tool image are
linux-imx-mfgtool and u-boot-mfgtool.
To build a manufacturing image do the following:
$ bitbake fsl-image-mfgtool-initramfs
4,956件の閲覧回数
sankarsalla
I am trying to port oreo 8.0 in imx6q based carrier board, i am booting board from sdcard, after mounting rootfile system it is trying to start services from vendor folder continuoulsly and i am getting only bootlogo in  LCD, please see the below log, could you please help me how to solve the issue
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Jan  1 2014, 17:13:19.
Port /dev/ttyUSB0, 14:42:22
Press CTRL-A Z for help on special keys
U-Boot SPL 2017.03-g2537522-dirty (Jul 03 2018 - 15:47:03)
Boot device 1
Trying to boot from MMC1
CPU:   Automotive temperature grade (-40C to 125C) at 46C
Reset cause: POR
I2C:   ready
DRAM:  1 GiB
NAND:  1024 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
Normal Boot
reading zImage
11749400 bytes read in 665 ms (16.8 MiB/s)
51474 bytes read in 23 ms (2.1 MiB/s)
Starting kernel ...
Linux version 4.9.17 (ananth@dhoni) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #6 SMP PREEMPT Tue Jul 24 12:34:09 IST 2018
Kernel command line: console=ttymxc1,115200 init=/init video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc1 consoleblank=0 androidboot.hardware=freescale cma=448M galcore.contiguousSize=33554432 buildvariant=userdebug androidboot.selinux=permissive arm_freq=1000 fbmem=48M androidboot.soc_type=imx6q androidboot.dm_verity=disabled
Brought up 4 CPUs
audit: type=2000 audit(0.850:1): initialized
[drm] Initialized
brd: module loaded
loop: module loaded
platform caam_sm: [0000] 8c e1 f1 14 60 08 4e 49
platform caam_sm: [0008] ca 40 b3 dd 58 f1 bc 05
platform caam_sm: [0000] c6 11 a1 4f 79 eb ad 8d
platform caam_sm: [0008] a5 46 9b bb 42 5a 1d ff
platform caam_sm: [0000] 9b dd bb 66 8b 2c 5e 67
platform caam_sm: [0008] cd db a4 98 91 cd c7 03
platform caam_sm: [0016] e4 91 91 07 de f3 ed 2d
platform caam_sm: [0024] 3e 75 f3 7d d6 3d 5b bf
platform caam_sm: [0000] e5 0f bf 58 8e b4 ba bd
platform caam_sm: [0008] f1 46 c6 55 b2 8b 5b fc
platform caam_sm: [0016] 5a 69 a3 1e ea 8e 32 4b
platform caam_sm: [0024] 30 84 a7 06 b8 73 35 ec
platform caam_sm: [0000] 80 34 88 db 56 8f e3 1c
platform caam_sm: [0008] 2e 93 6c f8 76 a4 e0 e0
platform caam_sm: [0016] 32 55 f4 ed 78 f8 b1 f6
platform caam_sm: [0024] ee 19 19 28 b3 87 90 c0
platform caam_sm: [0032] 4a 56 92 a2 6f c1 f9 6b
platform caam_sm: [0040] 63 26 c6 e7 d7 08 5a c4
platform caam_sm: [0048] 92 d0 e5 de b1 04 a5 32
platform caam_sm: [0000] 9f c8 71 df 69 e1 00 1e
platform caam_sm: [0008] c5 26 40 0d d9 ea 0b 6a
platform caam_sm: [0016] b2 3a d2 c2 ee 50 e4 4a
platform caam_sm: [0024] a9 da a9 36 66 cc 57 ab
platform caam_sm: [0032] 0a d1 a7 9d e5 a9 de c4
platform caam_sm: [0040] 4b f2 0b be 7a 0f ae 92
platform caam_sm: [0048] 18 ae 7e 78 29 66 09 44
platform caam_sm: [0056] d1 d4 32 86 a6 f3 6d f2
platform caam_sm: [0000] 24 88 b4 34 09 1f ae 26
platform caam_sm: [0008] a2 a9 6f b3 d9 37 c2 58
platform caam_sm: [0016] 17 55 2a 2d a5 85 80 e8
platform caam_sm: [0024] 4b 97 d1 52 c0 45 61 fc
platform caam_sm: [0032] dc ac 0a 15 4b 44 13 6f
platform caam_sm: [0040] 4c 49 2e 69 fb bb bd 42
platform caam_sm: [0048] a8 cc a5 4b 04 be a7 d6
platform caam_sm: [0056] f2 2a 2b 83 1c ec 0b dc
platform caam_sm: [0064] e7 ab 1b 0e 57 ce f1 dc
platform caam_sm: [0000] 4c a2 a2 aa e5 b0 2c c8
platform caam_sm: [0008] 26 f6 82 84 c6 83 b9 8d
platform caam_sm: [0016] f8 d2 4d e4 ac 66 21 13
platform caam_sm: [0024] 10 90 43 91 17 2e 1c b7
platform caam_sm: [0032] e0 ff da ae 6d e7 e3 3c
platform caam_sm: [0040] c7 f5 b6 7c 5d 89 9e 51
platform caam_sm: [0048] 9e 44 4b 88 99 e5 6a 76
platform caam_sm: [0056] 3c 80 56 90 d0 3a f9 06
platform caam_sm: [0064] 9d 76 94 ae e7 04 95 8f
platform caam_sm: [0072] c8 8a f8 88 85 07 e9 55
platform caam_sm: [0000] ef 51 23 7e ca ea 04 8a
platform caam_sm: [0008] d7 48 d8 7d e1 d2 38 b4
platform caam_sm: [0016] c4 72 92 c9 1b d2 0b c4
platform caam_sm: [0024] 80 ba 57 e2 28 f2 4c 6c
ashmem: initialized
u32 classifier
    Actions configured
mip6: Mobile IPv6
dhd_module_init in
lcd_3v3: disabling
VCC_CAM0: disabling
ALSA device list:
audit: type=1403 audit(4.070:2): policy loaded auid=4294967295 ses=4294967295
ueventd: Coldboot took 0.262869 seconds
audit: type=1400 audit(5.440:3): avc:  granted  { read } for  pid=1 comm="init" name="ttymxc1" dev="tmpfs" ino=11366 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tcla
ss=chr_file
audit: type=1400 audit(5.460:4): avc:  granted  { read open } for  pid=1 comm="init" path="/dev/ttymxc1" dev="tmpfs" ino=11366 scontext=u:r:init:s0 tcontext=u:object_r:tty_devi
ce:s0 tclass=chr_file
read descriptors
read strings
init: starting service 'bluetooth-1-0'...
init: property_set("ro.boottime.bluetooth-1-0", "10656554667") failed: property already set
init: cannot execve('/vendor/bin/hw/android.hardware.bluetooth@1.0-service'): No such file or directory
init: starting service 'camera-provider-2-4'...
init: couldn't write 256 to /dev/cpuset/camera-daemon/tasks: No such file or directory
init: property_set("ro.boottime.camera-provider-2-4", "12024838668") failed: property already set
init: cannot execve('/vendor/bin/hw/android.hardware.camera.provider@2.4-service'): No such file or directory
init: starting service 'configstore-hal-1-0'...
init: property_set("ro.boottime.configstore-hal-1-0", "13008199334") failed: property already set
init: starting service 'gralloc-2-0'...
init: starting service 'mediacodec'...
init: property_set("ro.boottime.mediacodec", "15749956335") failed: property already set
init: starting service 'memtrack-hal-1-0'...
init: cannot execve('/vendor/bin/hw/android.hardware.memtrack@1.0-service'): No such file or directory
init: property_set("ro.boottime.memtrack-hal-1-0", "16548821668") failed: property already set
init: starting service 'power-hal-1-0'...
init: cannot execve('/vendor/bin/hw/android.hardware.power@1.0-service'): No such file or directory
init: property_set("ro.boottime.power-hal-1-0", "18021136002") failed: property already set
init: starting service 'sensors-hal-1-0'...
init: property_set("ro.boottime.sensors-hal-1-0", "18921830335") failed: property already set
init: cannot execve('/vendor/bin/hw/android.hardware.wifi@1.0-service'): No such file or directory
init: starting service 'ril-daemon'...
init: property_set("ro.boottime.ril-daemon", "21563680002") failed: property already set
init: cannot execve('/vendor/bin/hw/rild'): No such file or directory
init: starting service 'vndservicemanager'...
init: property_set("ro.boottime.vndservicemanager", "22352506669") failed: property already set
init: cannot execve('/vendor/bin/vndservicemanager'): No such file or directory
init: Service 'bluetooth-1-0' (pid 254) exited with status 127
init: Sending signal 9 to service 'bluetooth-1-0' (pid 254) process group...
init: kill(-254, 9) failed: No such process
init: property_set("ro.boottime.configstore-hal-1-0", "25848976336") failed: property already set
init: cannot execve('/vendor/bin/hw/android.hardware.configstore@1.0-service'): No such file or directory
4,956件の閲覧回数
vinays
Hi sankar salla
i am also having the same problem . please tell how did you solve this problem
4,956件の閲覧回数
sankarsalla
Hi Sir,
Reset cause: POR
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
=> run mmcargs
=> boot
reading zImage
Starting kernel ...
Brought up 4 CPUs
[drm] Initialized
brd: module loaded
loop: module loaded
ashmem: initialized
u32 classifier
Actions configured
mip6: Mobile IPv6
dhd_module_init in
lcd_3v3: disabling
VCC_CAM0: disabling
ALSA device list:
read descriptors
read strings
Anantha
