1. what is maximum operating current MK10DN512ZVLQ10 @ st3v3.
2. How to Select LDO for IMXRT1064 New Design ..we don't use DDR, Audio section , how much Voltage and Current required .
Sakthi.
Hello
Hope you are well.
1. Please check chapter 4.4 from the datasheet: https://www.nxp.com/docs/en/data-sheet/K10P144M100SF2V2.pdf
2. You need to assure that the power supply is on the supported operating range, you can check it in the device datasheet.
Additionally, for RT1064 it is important to refer to the Hardware Development User Guide for guidelines referring to hardware.
If you have more questions do not hesitate to ask me.
Omar
