电源管理
Power Management
891 次查看
shalanyang
Hello, I want to know how to use SPI,USB,and Ethernet power management in imx8qxp mek board? could you help me ? for example: how could I suspend or resume in imx8qxp(SPI&&USB&&Ethernet Module)? thanks!!!!
752 次查看
joanxie
for power management, you can refer to the application note as below:
https://www.nxp.com/docs/en/application-note/AN12338.pdf
752 次查看
shalanyang
tks,Joan,
              for example, I want to wakeup SOC by SPI,In spi_fsl_lpspi.c the function is empty(imx8qxp mek board)
              the driver code is follow:
#ifdef CONFIG_PM_SLEEP
static int fsl_lpspi_suspend(struct device *dev)
int ret;
pinctrl_pm_select_sleep_state(dev);
ret = pm_runtime_force_suspend(dev);
return ret;
static int fsl_lpspi_resume(struct device *dev)
int ret;
ret = pm_runtime_force_resume(dev);
if (ret) {
dev_err(dev, "Error in resume: %d\n", ret);
return ret;
pinctrl_pm_select_default_state(dev);
return 0;
#endif /* CONFIG_PM_SLEEP */
static inline int pm_generic_runtime_suspend(struct device *dev) { return 0; }
static inline int pm_generic_runtime_resume(struct device *dev) { return 0; }
static inline int pm_runtime_force_suspend(struct device *dev) { return 0; }
static inline int pm_runtime_force_resume(struct device *dev) { return 0; }
the SPI can not support suspend or resume?
752 次查看
shalanyang
Could you help me ???
