Porting from Quad to quad plus
946件の閲覧回数
manjunathjoshi
Contributor V
Hello All,
I need to move from earlier i.mx6 quad processor to new quad plus in one of our boards, i want to know what is the effort required to port bootloader and kernel from the same.
Is there any change required in pin mux ?
Thanks and regards,
Manju
ラベル(2)
850件の閲覧回数
Yuri
   You may look at http://cache.nxp.com/files/32bit/doc/eng_bulletin/EB810.pdf
It makes sense to use the recent Linux NXP BSP, which supports the QP.
i.MX 6 Series Software and Development Tool|NXP
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
851件の閲覧回数
Yuri
Yuri
