I have a Sabre board with iMX6Q, and I noticed the MIPI port (J5) is not populated. I looked at the current schematic, and it shows the MIPI components "not populated". This seems like such an elementary question that has probably been asked many times, but I couldn't find it. If I populate the MIPI components (J5, C602, C50, SH501, U10, R26, C585, C588, C28, C29, L10, L25, R726, C30, C587) will the MIPI port work from a hardware standpoint? I plan on purchasing a MIPI camera for a surveillance / face recognition project, and want to insure it will interface to the Sabre.
Thanks...
John
Solved! Go to Solution.
Hi John
yes it should work, as schematic is similar to SDP board
SPF-27417 i.MX6_SABRE_SDP_DESIGNFILES
where MIPI port (J5) is populated.
Hi John
Thanks, I'll order the parts...
