We try to play a video by "Cactus Player" on android 4.3. It can play but it will lag in every 2~3 seconds.
Have anyone the same issue. How to solve?
Follow is the information about the video,
- Video is Mpeg4
- Video streaming info : 9493Kbps, 1248*702(16:9) and 29.970 fps, AVC(High@L5.0) (CABAC/16 Ref Frames)
- Audio streaming info : 96Kbps, 48.0KHz,AAC(LC)
Test Enviroment is
1. CPU is imx6 DL
2. OS: android_jb4.3_1.1.0
3. Test Video :
https://drive.google.com/file/d/0B6wokCK_hdHTUlpQNDM1bGhsWFU/edit?usp=sharing
4. Test Step :
a. Open Cactus Player
Open file "MXBK0502.mov" from USB disk
5. Test Result:
Video have lag every one and two seconds .
Reference video: https://docs.google.com/file/d/0B6wokCK_hdHTTzhjWUpKM1BpOFk/edit
Kevin
Hi, Kevin,
Have you solved this issue ?
I am handling the similar issue. Would you please give me any suggestion ?
Peter
Hello Kevin,
I cannot download the video, it appears to be erased, can you please repost it so I can try to reproduct the problem?
Hi SerchMX,
I've re-share it. You can get it from the follow link,
https://drive.google.com/file/d/0B6wokCK_hdHTTzhjWUpKM1BpOFk/edit?usp=sharing
Thanks!!
Hi Kevin
had you tried play from SD card, is there lag ?
Hi igor,
We test it and the same result.
Kevin
