Phonon not show video
Search instead for
enaud
hi all,
I've resolved error of phonon with export QT_PLUGIN_PATH='/usr/plugin' but now my application start but i no view video i view only a black box.. If i type: gplay MOV008.mp4 I view correclty my vide on full screen. But with my QT app no Code of my app is:
#include "mainwindow.h"
#include "ui_mainwindow.h"
#include <phonon/VideoPlayer>
#include <phonon/MediaObject>
#include <phonon/MediaSource>
MainWindow::MainWindow(QWidget *parent) :
QMainWindow(parent),
ui(new Ui::MainWindow)
ui->setupUi(this);
Phonon::MediaObject *media = new Phonon::MediaObject(this);
media->setCurrentSource(Phonon::MediaSource(QString("MOV008.mp4")));
ui->videoPlayer->play(media->currentSource());
MainWindow::~MainWindow()
delete ui;
When i run my app i view: (Look at this link) http://pastebin.com/9gjxv5nj
thanks
enaud
I have Lookup error on ARM
Hitex
Once you download it goto the directory and change the permission using terminal
chmod 777 -R Simple
Hitex
1st One is a x86 Executable
2nd is same ARM executable
with 4 buttons, Open,Play,Pause,Stop check if it works....
Hitesh said:
enaud said:
Hitex
enaud said:
enaud
enaud
with Gplay yes but on my app I no view and not hear nothing.
Hitex
Hi, I faced the same problem , Code works fine on x86, however it dosent play video on I.MX53QSB. There is some problem with AVI and MP4. AVI file will not play..... with MP4 you will get only audio ..... Try with .wmv file you will get audio and video in frames atleast you will get some display, however still it is not upto the expectation
