Parameters for imx8mp HDMI pixel clock
890 次查看
TeroLP
linux-imx has samsung_phy_pll_cfg defined in drivers/phy/freescale/phy-fsl-samsung-hdmi.c . To support HDMI display with certain pixel clock, config struct has to have parameters for that frequency.
I'm using evalutation kit, and would need parameters for two clocks:
238760000 (2560x1440) and 150000000 (1920x1200).
I would appreciate a ready made table or a tool to generate that table.
879 次查看
joanxie
I've mailed to you, pls check it
5 回复数
880 次查看
joanxie
284 次查看
Miles_x
Hi, joanxie
I have a simliar problem,  use iMX8MP platform, HDMI 1280x800@60HZ output,  please send me the tool, thanks!
280 次查看
joanxie
this isn't available for customers, pls create a new case for your display, and tell me what pixel clock you need
262 次查看
Miles_x
738 次查看
Stefano_Radaelli
can I have those informations please? I have to add a 2560x1440 HDMI display, with 241500000
 clock. Is it possible?
Thank you,
Stefano
