PWM2 Query for i.MX6Q
1,049 次查看
himalimunshi
I want to use PWM2 on i.MX6Q. While i am adding PWM2 node with IOMUX settings - MX6QDL_PAD_GPIO_1__PWM2_OUT in device tree, my board gets reboot every time after giving log - Starting kernel ... . I can not able to get reset cause.
I am using Linux kernel - 4.1.15_2.0.0 with Yocto BSP Krogoth- 4.1.15_2.0.0
919 次查看
igorpadykov
Hi himali
for pwm2 settings example one can look at BD nitrogen board dts:
linux-imx6/imx6qdl-nitrogen6_max.dtsi at boundary-imx_4.1.15_1.0.0_ga · boundarydevices/linux-imx6 ·...
919 次查看
himalimunshi
Hi igor
I am using these settings only for dts as mentioned in above link.
&pwm2 {
         pinctrl-names = "default";
         pinctrl-0 = <&pinctrl_pwm2>;
         status = "okay";
IOMUX Settings:
pinctrl_pwm2: pwm2grp {
fsl,pins = <
           MX6QDL_PAD_GPIO_1__PWM2_OUT 0x1b0b1
- himali
919 次查看
jaymind
Hi Himali,
The PWM configuration is correct.
Are you still facing that PWM issue for i.MX6Q?
If yes then,
Share Kernel boot-up log and board's ".dts" file.
Also, share some basic details of your development environment. I.e. Which development board (custom!) you are using?
