PF3000 i.MX 6UL
PF3000 i.MX 6UL
924件の閲覧回数
ricardoferreira
Is there any design reference for the component PF3000 with the i.MX 6UL using DDR3L? I can't find any documentation about the OTP code or layout guide to use with the MC34PF3000A7EP or the MC32PF3000A7EP.
Thank you very much in advance,
Ricardo F.
3 返答(返信)
645件の閲覧回数
steveglover
Freescale have the X-MCIMX6UL-9x9EVK-CM in development that uses a PF3000. Talk nicely to your local FAE and you should be able to get a preliminary schematic.
645件の閲覧回数
reyes
You can contact your local FAE or “Submit a New Issue” in www.nxp.com/support in order to try to get a copy of a preliminary schematics and more details about of the MCIMX6UL-CM board.
Jose
645件の閲覧回数
reyes
Hi Ricardo,
There are no reference designs about it, however, there are some documents that may be helpful:
  1. Application note AN5132 “PF3000 OTP Programming Instructions”: www.nxp.com/files/analog/doc/app_note/AN5132.pdf
  2. Application note AN5094 “PF3000 Layout Guidelines”: www.nxp.com/files/analog/doc/app_note/AN5094.pdf
I hope this information can be helpful.
Jose
