On our custom board, we are going to use a codec which gives PCM output.
Please let us know in perspective of IMX6Q processor, how PCM differs from I2S.
At many places, it is mentioned that PCM is similar to I2S.
Could we use the same "ssi interface" driver for both PCM & I2S.
Bikash
Hi Bikas,
Have to come to any conclusion regarding this?
Sumit
Hi bikash
"PCM" word is too generic and vague to provide accurate answer,
some PCM formats may be supported, some not.
Suggest to check codec datasheet and compare with i.MX6 RM SSI chapter
to understand if it can be supported.
