Hi:
Recently, I found that my development board always fails to detect the SSD in the PCIe1 slot after a period of use. What could be causing this issue? Currently, I am using BSP 4.19.35(yocto Warrior). It worked fine after replacing the CPU.Can you provide some suggestions?
![Eddy1_0-1708250392841.png Eddy1_0-1708250392841.png](https://community.nxp.com/t5/image/serverpage/image-id/263590iE5FDE056C163D759/image-size/medium?v=v2&px=400)
