PCIE_CTRL0_PERST_B pin configuration (imx8dx)
1,108 次查看
johny_kim
If specific pin(PCIE_CTRL0_PERST_B) supports both 1.8V and 3.3V, How can I control this voltage level in IMX8DX?
What register supports this voltage level control?
1 回复
1,024 次查看
jamesbone
Hello Hyun Kim,
Unfortunately the i.MX8DX, has not been release, so we are not able to share any information since it is subject to change.
My advise it is that you need to check in the PCIE pads, there is going to be a register that can select the power rail
