Overlay frame buffer support on iMX6SL evk.
5,119 次查看
jeminmorabia
In my iMX6SL evk board I am not able to see /dev/fb1 after start up.
Do iMX6SL support overlay frame buffer? How can I enable it?
In iMX6QDL processors IPU provides overlay frame buffer support.
Jemin Morabia
标记 (1)
4,387 次查看
joanxie
mx6sl doesn't ipu, just has EPDC controler, which doesn't support overlay.
5 回复数
4,388 次查看
joanxie
4,387 次查看
ramd
Xie,
Doesn't IMX6SL have GPU2D support with EPDC controller ?
4,383 次查看
Rita_Wang
Hi Morabia,
In the documents i.MX_6SoloLite_EVK_Linux_Release_Notes.pdf and i.MX_6SoloLite_Linux_Reference_Manual.pdf you can see that "Support for screen updates from an alternate (overlay) buffer".
Here I attached them for you, please have a check. Hope this can help you.
Dan
4,383 次查看
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g. i.MX Community ) to get it visible for active members.
For details please see general advice Where to post a Discussion? (https://community.freescale.com/docs/DOC-99909 )
Thank you for using Freescale Community.
4,383 次查看
jeminmorabia
Thanks Wlodek_D. for your guidance.
