In my iMX6SL evk board I am not able to see /dev/fb1 after start up.
Do iMX6SL support overlay frame buffer? How can I enable it?
In iMX6QDL processors IPU provides overlay frame buffer support.
Jemin Morabia
Solved! Go to Solution.
mx6sl doesn't ipu, just has EPDC controler, which doesn't support overlay.
Xie,
Doesn't IMX6SL have GPU2D support with EPDC controller ?
Hi Morabia,
In the documents i.MX_6SoloLite_EVK_Linux_Release_Notes.pdf and i.MX_6SoloLite_Linux_Reference_Manual.pdf you can see that "Support for screen updates from an alternate (overlay) buffer".
Here I attached them for you, please have a check. Hope this can help you.
Dan
Thank you for your post, however please consider moving it to the right community place (e.g. i.MX Community ) to get it visible for active members.
For details please see general advice Where to post a Discussion? (https://community.freescale.com/docs/DOC-99909 )
Thank you for using Freescale Community.
Thanks Wlodek_D. for your guidance.
