The IMMX8MMIEC datasheet requires a minimum drive level of 100uW for the 24MHz crystal and a maximum equivalent series resistance ESR of 80Ω, as shown in Figure.
What is the effect of a crystal with a drive level of less than 100uW? (The typical drive level of a passive crystal is 10uW and the maximum is 100uW, does it meet the requirements?)
解決済! 解決策の投稿を見る。
Hi @DanielDuJijun,
I hope you are doing well.
Please accept my apologies for the delay in response.
The datasheet mentions the minimum and maximum drive levels to be 10.0 uW to 100uW.
Please refer to the latest datasheet from this link.
Thanks & Regards,
Ritesh M Patel
Hi @DanielDuJijun,
Thanks & Regards,
Ritesh M Patel
