On IMX8MP LVDS display with 6.1 kernel is not working which is working on 5.15 kernel
Chandrasekhar-carrier
Hi Team, we are able to bring-up the LVDS display on 5.15 kernel on imx8mp custom board, but when we are porting from 5.15 to 6.1 kernel LVDS display is not working.
Below are the panel modifcations added:
With the same below modfications display is working in 5.15 kernel. So need supoort to bringup the display.
drivers/gpu/drm/panel/panel-simple.c | 97 ++++++++++++++++++++++++++++
1 file changed, 97 insertions(+)
diff --git a/drivers/gpu/drm/panel/panel-simple.c b/drivers/gpu/drm/panel/panel-simple.c
index b73669808347..605dce99d1ab 100644
--- a/drivers/gpu/drm/panel/panel-simple.c
+++ b/drivers/gpu/drm/panel/panel-simple.c
@@ -2128,6 +2128,94 @@ static const struct panel_desc hitachi_tx23d38vm0caa = {
+static const struct display_timing auo_g156han04_0_timings = {
+ .pixelclock = { 141000000, 141000000, 141000000 },
+ .hactive = { 1920, 1920, 1920 },
+ .hfront_porch = { 60, 60, 60 },
+ .hback_porch = { 60, 60, 60 },
+ .hsync_len = { 64, 64, 64 },
+ .vactive = { 1080, 1080, 1080 },
+ .vfront_porch = { 12, 12, 12 },
+ .vback_porch = { 12, 12, 12 },
+ .vsync_len = { 12, 12, 12 },
+static const struct panel_desc auo_g156han04_0 = {
+ .timings = &auo_g156han04_0_timings,
+ .num_timings = 1,
+ .bpc = 8,
+ .size = {
+ .width = 344,
+ .height = 194,
+ .delay = {
+ .prepare = 10,
+ .enable = 50,
+ .disable = 50,
+ .unprepare = 200,
+ .bus_format = MEDIA_BUS_FMT_RGB888_1X24,
+static const struct display_timing lxd_m773a_timings = {
+ .pixelclock = { 60000000, 60000000, 60000000 },
+ .hactive = { 1024, 1024, 1024 },
+ .hfront_porch = { 40, 40, 40 },
+ .hback_porch = { 40, 40, 40 },
+ .hsync_len = { 20, 20, 20 },
+ .vactive = { 600, 600, 600 },
+ .vfront_porch = { 20, 20, 20 },
+ .vback_porch = { 20, 20, 20 },
+ .vsync_len = { 10, 10, 10 },
+static const struct panel_desc lxd_m773a = {
+ .timings = &lxd_m773a_timings,
+ .num_timings = 1,
+ .bpc = 8,
+ .size = {
+ .width = 154,
+ .height = 85,
+ .delay = {
+ .prepare = 10,
+ .enable = 50,
+ .disable = 50,
+ .unprepare = 200,
+static const struct display_timing lxd_m776a_timings = {
+static const struct panel_desc lxd_m776a = {
+ .timings = &lxd_m776a_timings,
+ .num_timings = 1,
+ .bpc = 8,
+ .size = {
+ .width = 222,
+ .height = 125,
+ .delay = {
+ .prepare = 10,
+ .enable = 50,
+ .disable = 50,
+ .unprepare = 200,
static const struct drm_display_mode innolux_at043tn24_mode = {
.clock = 9000,
.hdisplay = 480,
@@ -4201,6 +4289,15 @@ static const struct of_device_id platform_of_match[] = {
.compatible = "hit,tx23d38vm0caa",
.data = &hitachi_tx23d38vm0caa
+ .compatible = "lxd,m773a",
+ .data = &lxd_m773a,
+ .compatible = "lxd,m776a",
+ .data = &lxd_m776a,
+ .compatible = "auo,g156han04_0",
+ .data = &auo_g156han04_0,
.compatible = "innolux,at043tn24",
.data = &innolux_at043tn24,
2.34.1
Here is the DTS file used:
lvds0_panel {
status = "okay";
compatible = "lxd,m776a";
backlight = <&lvds_backlight>;
enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
port {
panel_lvds_in: endpoint {
remote-endpoint = <&lvds_out>;
lvds_backlight {
enable-gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>;
// gpio3_IO23 on lec-imx8mp is display mux
reg_mipi_lvds_select: regulator-mipi-lvds {
compatible = "regulator-fixed";
regulator-name = "mipi_lvds_select_vbus";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_disp_select>;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
gpio = <&gpio3 23 GPIO_ACTIVE_HIGH>;
enable-active-low;
regulator-always-on;
&ldb {
status = "okay";
//fsl,dual-channel;
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
status = "okay";
/delete-node/ port@1;
port@1 {
reg = <1>;
lvds_out: endpoint {
remote-endpoint = <&panel_lvds_in>;
&ldb_phy {
status = "okay";
&i2c3 {
touchscreen@41 {
compatible = "ilitek,ili251x";
pinctrl-0 = <&pinctrl_touch_en &pinctrl_touch_rst>;
reg = <0x41>;
interrupt-parent = <&gpio1>;
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
touchscreen-inverted-x;
touchscreen-inverted-y;
@griffin.peterson@nxp.com, @JainthKumar.B@Carrier.com
after adding the below flags in the panel_desc then display is working as expected
.bus_format = MEDIA_BUS_FMT_RGB888_1X7X4_SPWG,
.bus_flags = DRM_BUS_FLAG_DE_HIGH,
.connector_type = DRM_MODE_CONNECTOR_LVDS,
There are no error messages, but display is not coming as expected
Is there any clock related changes we need to add in 6.1 Kernel?? or any other suggestions.
hi @joanxie
The Display backlight is initializing but on the display output is coming like below
So unable to figure out what modifications went wrong
joanxie
did you change any source code in the 5.15? did you just use the default lvds driver? as I known, current bsp couldn't support 60Mhz lvds display(single channel) as default, you need change the source code, if you change the 5.15 bsp, did you change corresponding to the 6.1?
We didn't do any bsp changes except the panel detail structures are added in 5.15 kernel. So did the same modifications in the 6.1 kernel as well
joanxie
do you mind dumping the clock to check? could you get the correct clock for your lvds panel, I checked the ldb driver, I don't find anything change would affect your display
joanxie
what do you mean "not working"?do you get anything error messages?
%3CLINGO-SUB%20id%3D%22lingo-sub-1897183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOn%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Team%2C%20we%20are%20able%20to%20bring-up%20the%20LVDS%20display%20on%205.15%20kernel%20on%20imx8mp%20custom%20board%2C%20but%20when%20we%20are%20porting%20from%205.15%20to%206.1%20kernel%20LVDS%20display%20is%20not%20working.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EBelow%20are%20the%20panel%20modifcations%20added%3A%3CBR%20%2F%3E%3CBR%20%2F%3EWith%20the%20same%20below%20modfications%20display%20is%20working%20in%205.15%20kernel.%20So%20need%20supoort%20to%20bringup%20the%20display.%3C%2FP%3E%3CP%3Edrivers%2Fgpu%2Fdrm%2Fpanel%2Fpanel-simple.c%20%7C%2097%20%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3CBR%20%2F%3E1%20file%20changed%2C%2097%20insertions(%2B)%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Fdrivers%2Fgpu%2Fdrm%2Fpanel%2Fpanel-simple.c%20b%2Fdrivers%2Fgpu%2Fdrm%2Fpanel%2Fpanel-simple.c%3CBR%20%2F%3Eindex%20b73669808347..605dce99d1ab%20100644%3CBR%20%2F%3E---%20a%2Fdrivers%2Fgpu%2Fdrm%2Fpanel%2Fpanel-simple.c%3CBR%20%2F%3E%2B%2B%2B%20b%2Fdrivers%2Fgpu%2Fdrm%2Fpanel%2Fpanel-simple.c%3CBR%20%2F%3E%40%40%20-2128%2C6%20%2B2128%2C94%20%40%40%20static%20const%20struct%20panel_desc%20hitachi_tx23d38vm0caa%20%3D%20%7B%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%2Bstatic%20const%20struct%20display_timing%20auo_g156han04_0_timings%20%3D%20%7B%3CBR%20%2F%3E%2B%20.pixelclock%20%3D%20%7B%20141000000%2C%20141000000%2C%20141000000%20%7D%2C%3CBR%20%2F%3E%2B%20.hactive%20%3D%20%7B%201920%2C%201920%2C%201920%20%7D%2C%3CBR%20%2F%3E%2B%20.hfront_porch%20%3D%20%7B%2060%2C%2060%2C%2060%20%7D%2C%3CBR%20%2F%3E%2B%20.hback_porch%20%3D%20%7B%2060%2C%2060%2C%2060%20%7D%2C%3CBR%20%2F%3E%2B%20.hsync_len%20%3D%20%7B%2064%2C%2064%2C%2064%20%7D%2C%3CBR%20%2F%3E%2B%20.vactive%20%3D%20%7B%201080%2C%201080%2C%201080%20%7D%2C%3CBR%20%2F%3E%2B%20.vfront_porch%20%3D%20%7B%2012%2C%2012%2C%2012%20%7D%2C%3CBR%20%2F%3E%2B%20.vback_porch%20%3D%20%7B%2012%2C%2012%2C%2012%20%7D%2C%3CBR%20%2F%3E%2B%20.vsync_len%20%3D%20%7B%2012%2C%2012%2C%2012%20%7D%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bstatic%20const%20struct%20panel_desc%20auo_g156han04_0%20%3D%20%7B%3CBR%20%2F%3E%2B%20.timings%20%3D%20%26amp%3Bauo_g156han04_0_timings%2C%3CBR%20%2F%3E%2B%20.num_timings%20%3D%201%2C%3CBR%20%2F%3E%2B%20.bpc%20%3D%208%2C%3CBR%20%2F%3E%2B%20.size%20%3D%20%7B%3CBR%20%2F%3E%2B%20.width%20%3D%20344%2C%3CBR%20%2F%3E%2B%20.height%20%3D%20194%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%2B%20.delay%20%3D%20%7B%3CBR%20%2F%3E%2B%20.prepare%20%3D%2010%2C%3CBR%20%2F%3E%2B%20.enable%20%3D%2050%2C%3CBR%20%2F%3E%2B%20.disable%20%3D%2050%2C%3CBR%20%2F%3E%2B%20.unprepare%20%3D%20200%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%2B%20.bus_format%20%3D%20MEDIA_BUS_FMT_RGB888_1X24%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bstatic%20const%20struct%20display_timing%20lxd_m773a_timings%20%3D%20%7B%3CBR%20%2F%3E%2B%20.pixelclock%20%3D%20%7B%2060000000%2C%2060000000%2C%2060000000%20%7D%2C%3CBR%20%2F%3E%2B%20.hactive%20%3D%20%7B%201024%2C%201024%2C%201024%20%7D%2C%3CBR%20%2F%3E%2B%20.hfront_porch%20%3D%20%7B%2040%2C%2040%2C%2040%20%7D%2C%3CBR%20%2F%3E%2B%20.hback_porch%20%3D%20%7B%2040%2C%2040%2C%2040%20%7D%2C%3CBR%20%2F%3E%2B%20.hsync_len%20%3D%20%7B%2020%2C%2020%2C%2020%20%7D%2C%3CBR%20%2F%3E%2B%20.vactive%20%3D%20%7B%20600%2C%20600%2C%20600%20%7D%2C%3CBR%20%2F%3E%2B%20.vfront_porch%20%3D%20%7B%2020%2C%2020%2C%2020%20%7D%2C%3CBR%20%2F%3E%2B%20.vback_porch%20%3D%20%7B%2020%2C%2020%2C%2020%20%7D%2C%3CBR%20%2F%3E%2B%20.vsync_len%20%3D%20%7B%2010%2C%2010%2C%2010%20%7D%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bstatic%20const%20struct%20panel_desc%20lxd_m773a%20%3D%20%7B%3CBR%20%2F%3E%2B%20.timings%20%3D%20%26amp%3Blxd_m773a_timings%2C%3CBR%20%2F%3E%2B%20.num_timings%20%3D%201%2C%3CBR%20%2F%3E%2B%20.bpc%20%3D%208%2C%3CBR%20%2F%3E%2B%20.size%20%3D%20%7B%3CBR%20%2F%3E%2B%20.width%20%3D%20154%2C%3CBR%20%2F%3E%2B%20.height%20%3D%2085%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%2B%20.delay%20%3D%20%7B%3CBR%20%2F%3E%2B%20.prepare%20%3D%2010%2C%3CBR%20%2F%3E%2B%20.enable%20%3D%2050%2C%3CBR%20%2F%3E%2B%20.disable%20%3D%2050%2C%3CBR%20%2F%3E%2B%20.unprepare%20%3D%20200%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%2B%20.bus_format%20%3D%20MEDIA_BUS_FMT_RGB888_1X24%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bstatic%20const%20struct%20display_timing%20lxd_m776a_timings%20%3D%20%7B%3CBR%20%2F%3E%2B%20.pixelclock%20%3D%20%7B%2060000000%2C%2060000000%2C%2060000000%20%7D%2C%3CBR%20%2F%3E%2B%20.hactive%20%3D%20%7B%201024%2C%201024%2C%201024%20%7D%2C%3CBR%20%2F%3E%2B%20.hfront_porch%20%3D%20%7B%2040%2C%2040%2C%2040%20%7D%2C%3CBR%20%2F%3E%2B%20.hback_porch%20%3D%20%7B%2040%2C%2040%2C%2040%20%7D%2C%3CBR%20%2F%3E%2B%20.hsync_len%20%3D%20%7B%2020%2C%2020%2C%2020%20%7D%2C%3CBR%20%2F%3E%2B%20.vactive%20%3D%20%7B%20600%2C%20600%2C%20600%20%7D%2C%3CBR%20%2F%3E%2B%20.vfront_porch%20%3D%20%7B%2020%2C%2020%2C%2020%20%7D%2C%3CBR%20%2F%3E%2B%20.vback_porch%20%3D%20%7B%2020%2C%2020%2C%2020%20%7D%2C%3CBR%20%2F%3E%2B%20.vsync_len%20%3D%20%7B%2010%2C%2010%2C%2010%20%7D%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2Bstatic%20const%20struct%20panel_desc%20lxd_m776a%20%3D%20%7B%3CBR%20%2F%3E%2B%20.timings%20%3D%20%26amp%3Blxd_m776a_timings%2C%3CBR%20%2F%3E%2B%20.num_timings%20%3D%201%2C%3CBR%20%2F%3E%2B%20.bpc%20%3D%208%2C%3CBR%20%2F%3E%2B%20.size%20%3D%20%7B%3CBR%20%2F%3E%2B%20.width%20%3D%20222%2C%3CBR%20%2F%3E%2B%20.height%20%3D%20125%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%2B%20.delay%20%3D%20%7B%3CBR%20%2F%3E%2B%20.prepare%20%3D%2010%2C%3CBR%20%2F%3E%2B%20.enable%20%3D%2050%2C%3CBR%20%2F%3E%2B%20.disable%20%3D%2050%2C%3CBR%20%2F%3E%2B%20.unprepare%20%3D%20200%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%2B%20.bus_format%20%3D%20MEDIA_BUS_FMT_RGB888_1X24%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%3CBR%20%2F%3Estatic%20const%20struct%20drm_display_mode%20innolux_at043tn24_mode%20%3D%20%7B%3CBR%20%2F%3E.clock%20%3D%209000%2C%3CBR%20%2F%3E.hdisplay%20%3D%20480%2C%3CBR%20%2F%3E%40%40%20-4201%2C6%20%2B4289%2C15%20%40%40%20static%20const%20struct%20of_device_id%20platform_of_match%5B%5D%20%3D%20%7B%3CBR%20%2F%3E.compatible%20%3D%20%22hit%2Ctx23d38vm0caa%22%2C%3CBR%20%2F%3E.data%20%3D%20%26amp%3Bhitachi_tx23d38vm0caa%3CBR%20%2F%3E%7D%2C%20%7B%3CBR%20%2F%3E%2B%20.compatible%20%3D%20%22lxd%2Cm773a%22%2C%3CBR%20%2F%3E%2B%20.data%20%3D%20%26amp%3Blxd_m773a%2C%3CBR%20%2F%3E%2B%20%7D%2C%20%7B%3CBR%20%2F%3E%2B%20.compatible%20%3D%20%22lxd%2Cm776a%22%2C%3CBR%20%2F%3E%2B%20.data%20%3D%20%26amp%3Blxd_m776a%2C%3CBR%20%2F%3E%2B%20%7D%2C%20%7B%3CBR%20%2F%3E%2B%20.compatible%20%3D%20%22auo%2Cg156han04_0%22%2C%3CBR%20%2F%3E%2B%20.data%20%3D%20%26amp%3Bauo_g156han04_0%2C%3CBR%20%2F%3E%2B%20%7D%2C%20%7B%3CBR%20%2F%3E.compatible%20%3D%20%22innolux%2Cat043tn24%22%2C%3CBR%20%2F%3E.data%20%3D%20%26amp%3Binnolux_at043tn24%2C%3CBR%20%2F%3E%7D%2C%20%7B%3CBR%20%2F%3E--%3CBR%20%2F%3E2.34.1%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHere%20is%20the%20DTS%20file%20used%3A%3C%2FP%3E%3CP%3E%2F%20%7B%3CBR%20%2F%3Elvds0_panel%20%7B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3Ecompatible%20%3D%20%22lxd%2Cm776a%22%3B%3CBR%20%2F%3Ebacklight%20%3D%20%26lt%3B%26amp%3Blvds_backlight%26gt%3B%3B%3CBR%20%2F%3Eenable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2013%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3Eport%20%7B%3CBR%20%2F%3Epanel_lvds_in%3A%20endpoint%20%7B%3CBR%20%2F%3Eremote-endpoint%20%3D%20%26lt%3B%26amp%3Blvds_out%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3Elvds_backlight%20%7B%3CBR%20%2F%3Eenable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%200%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%2F%2F%20gpio3_IO23%20on%20lec-imx8mp%20is%20display%20mux%3CBR%20%2F%3Ereg_mipi_lvds_select%3A%20regulator-mipi-lvds%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22regulator-fixed%22%3B%3CBR%20%2F%3Eregulator-name%20%3D%20%22mipi_lvds_select_vbus%22%3B%3CBR%20%2F%3Epinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_disp_select%26gt%3B%3B%3CBR%20%2F%3Eregulator-min-microvolt%20%3D%20%26lt%3B1800000%26gt%3B%3B%3CBR%20%2F%3Eregulator-max-microvolt%20%3D%20%26lt%3B1800000%26gt%3B%3B%3CBR%20%2F%3Egpio%20%3D%20%26lt%3B%26amp%3Bgpio3%2023%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3Eenable-active-low%3B%3CBR%20%2F%3Eregulator-always-on%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26amp%3Bldb%20%7B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%2F%2Ffsl%2Cdual-channel%3B%3CBR%20%2F%3Elvds-channel%400%20%7B%3CBR%20%2F%3Efsl%2Cdata-mapping%20%3D%20%22spwg%22%3B%3CBR%20%2F%3Efsl%2Cdata-width%20%3D%20%26lt%3B24%26gt%3B%3B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%2Fdelete-node%2F%20port%401%3B%3CBR%20%2F%3Eport%401%20%7B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3Elvds_out%3A%20endpoint%20%7B%3CBR%20%2F%3Eremote-endpoint%20%3D%20%26lt%3B%26amp%3Bpanel_lvds_in%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%26amp%3Bldb_phy%20%7B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%26amp%3Bi2c3%20%7B%3CBR%20%2F%3Etouchscreen%4041%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22ilitek%2Cili251x%22%3B%3CBR%20%2F%3Epinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_touch_en%20%26amp%3Bpinctrl_touch_rst%26gt%3B%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x41%26gt%3B%3B%3CBR%20%2F%3Einterrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio1%26gt%3B%3B%3CBR%20%2F%3Einterrupts%20%3D%20%26lt%3B0%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%3CBR%20%2F%3Ereset-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%207%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3Etouchscreen-inverted-x%3B%3CBR%20%2F%3Etouchscreen-inverted-y%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%40griffin.peterson%40nxp.com%2C%26nbsp%3B%40JainthKumar.B%40Carrier.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1904083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1904083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eafter%20adding%20the%20below%20flags%20in%20the%20panel_desc%20then%20display%20is%20working%20as%20expected%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E.bus_format%20%3D%20MEDIA_BUS_FMT_RGB888_1X7X4_SPWG%2C%3CBR%20%2F%3E.bus_flags%20%3D%20DRM_BUS_FLAG_DE_HIGH%2C%3CBR%20%2F%3E.connector_type%20%3D%20DRM_MODE_CONNECTOR_LVDS%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1899222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1899222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Edo%20you%20mind%20dumping%20the%20clock%20to%20check%3F%20could%20you%20get%20the%20correct%20clock%20for%20your%20lvds%20panel%2C%20I%20checked%20the%20ldb%20driver%2C%20I%20don't%20find%20anything%20change%20would%20affect%20your%20display%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWe%20didn't%20do%20any%20bsp%20changes%20except%20the%20panel%20detail%20structures%20are%20added%20in%205.15%20kernel.%20So%20did%20the%20same%20modifications%20in%20the%206.1%20kernel%20as%20well%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Edid%20you%20change%20any%20source%20code%20in%20the%205.15%3F%20did%20you%20just%20use%20the%20default%20lvds%20driver%3F%20as%20I%20known%2C%20current%20bsp%20couldn't%20support%2060Mhz%20lvds%20display(single%20channel)%20as%20default%2C%20you%20need%20change%20the%20source%20code%2C%20if%20you%20change%20the%205.15%20bsp%2C%20did%20you%20change%20corresponding%20to%20the%206.1%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThere%20are%20no%20error%20messages%2C%20but%20display%20is%20not%20coming%20as%20expected%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chandrasekharcarrier_0-1719937688455.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chandrasekharcarrier_0-1719937688455.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F286680i1AC4588767A5B96B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chandrasekharcarrier_0-1719937688455.png%22%20alt%3D%22Chandrasekharcarrier_0-1719937688455.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EIs%20there%20any%20clock%20related%20changes%20we%20need%20to%20add%20in%206.1%20Kernel%3F%3F%20or%20any%20other%20suggestions.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20Display%20backlight%20is%20initializing%20but%20on%20the%20display%20output%20is%20coming%20like%20below%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chandrasekharcarrier_0-1719933913035.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chandrasekharcarrier_0-1719933913035.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F286671i768A11085C23FAB6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chandrasekharcarrier_0-1719933913035.png%22%20alt%3D%22Chandrasekharcarrier_0-1719933913035.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3ESo%20unable%20to%20figure%20out%20what%20modifications%20went%20wrong%26nbsp%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20On%20IMX8MP%20LVDS%20display%20with%206.1%20kernel%20is%20not%20working%20which%20is%20working%20on%205.15%20kernel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ewhat%20do%20you%20mean%20%22not%20working%22%EF%BC%9Fdo%20you%20get%20anything%20error%20messages%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
