I'm writing linux kernel module for uart control of i.mx6d, i'm taking as example the imx.c and mxc_uart_early.c sources in ./drivers/tty/serial.
/* Enable Early MXC UART Clock */
clk_enable(device->clk);
port->uartclk = 5600000;
for example in imx.c source main clock is got from:
clk_get(&pdev->udev, "uart");
sport->port.uartclk = clk_get_rate(sport->clk);
I'm trying to figure out how it works in order to configure divisors and so on, also if i check on mxc_uart_early code is as follows:
I don't wanna use platform and uart struct but access directly registers, could you kindly suggest the steps to proceed or if there is some part to read to get it clear?
Best Regards
Miroglio Paolo
