Thank you in advance.
The LPDDR4, MT53B768M32D4NQ-062 WT:B, used in EVK is obsolete. Kindly suggest an alternative.
PIN TO PIN alternative?
I don't have this data sheet, you can check it, this isn't official supported part number, I found other customer used this to replace MT53B768M32D4NQ-062 WT:B successfully
maybe you can consider MT53E768M32D2ZW-046 AIT:C,
