Object detection custom application
1,508 次查看
kenizgandhi
I am using imx8mplus evk board. I have booted Linux version 5.10.9-1.0.0+g32513c25d8c7
I am developing my own object detection application using efficientdet_lite0 model. Below I am attaching the code files.
When I try to run the code in virtual env using the command python3 detect.py --model efficientdet_lite0.tflite, i am getting the following error : [ WARN:0] global /tmp/pip-req-build-h8zflkjv/opencv/modules/videoio/src/cap_v4l. cpp (890) open VIDEOIO(V4L2:/dev/video1): can't open camera by index
Without the virtual env, mipi camera is working fine but the model doesn't work. Can you please tell me how to solve this issue.
Thank You.
Kind Regards,
Keniz Gandhi
1,490 次查看
Zhiming_Liu
