Dear igorpadykov.
I checked "gst-inspect-1.0 imxv4l2src"
It showed the result as follows.
There is not available "Capabilities" configuration.
Please review logs and let me know how to solve it.
root@imx6ulevk:~# gst-inspect-1.0 imxv4l2src
====== IMXV4L2SRC: 4.1.4 build on Apr 7 2017 10:53:43. ======
Factory Details:
Rank primary + 1 (257)
Long-name IMX Video (video4linux2) Source
Klass Src/Video
Description Capture frames from IMX SoC video4linux2 device
Author Multimedia Team <shmmmw@freescale.com>
Plugin Details:
Name imxv4l2.imx
Description IMX SoC v4l2-based video source/sink
Filename /usr/lib/gstreamer-1.0/libgstimxv4l2plugins.so
Version 4.1.4
License LGPL
Source module imx-gst1.0-plugin
Binary package Freescle Gstreamer Multimedia Plugins
Origin URL http://www.freescale.com
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstPushSrc
+----GstImxV4l2Src
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
EMPTY
Element Flags:
no flags set
Element Implementation:
Has change_state() function: gst_base_src_change_state
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "imxv4l2src0"
parent : The parent of the object
Object of type "GstObject"
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
typefind : Run typefind before negotiating
Boolean. Default: false
do-timestamp : Apply current stream time to buffers
device : Device location
String. Default: "/dev/video0"
use-v4l2src-memory : Force allocate video frame buffer by V4L2 capture
Boolean. Default: true
frame-plus : set number of addtional frames for smoothly recording
Unsigned Integer. Range: 0 - 16 Default: 3
