I am working on a custom board with i.MX6ULL connected to a OV5640 camera module.
My dts and config details are attached.
I have looked at the various posts on related topics on the forum here and elsewhere and I am not sure where I am going wrong with this. Any pointers for trouble shooting this will help.
At this point I am not seeing any signal on the MCLK and hence no communication over I2C as well. So starting point for me is to get MCLK working.
Adding relevant section details here as well.
&i2c2 {
clock_frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c2>;
status = "okay";
ov5640: ov5640@3c {
compatible = "ov5640";
reg = <0x3c>;
pinctrl-0 = <&pinctrl_csi1>;
clocks = <&clks IMX6UL_CLK_CSI>;
clock-names = "csi_mclk";
// pwn-gpios = <&gpio1 2 1>;
// rst-gpios = <&gpio1 1 0>;
csi_id = <0>;
mclk = <24000000>;
mclk_source = <0>;
status = "okay";
port {
ov5640_ep: endpoint {
remote-endpoint = <&csi1_ep>;
iomux details:
pinctrl_csi1: csi1grp {
fsl,pins = <
MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x10071
MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088
MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088
MX6UL_PAD_CSI_HSYNC__CSI_HSYNC 0x1b088
MX6UL_PAD_CSI_DATA00__CSI_DATA02 0x1b088
MX6UL_PAD_CSI_DATA01__CSI_DATA03 0x1b088
MX6UL_PAD_CSI_DATA02__CSI_DATA04 0x1b088
MX6UL_PAD_CSI_DATA03__CSI_DATA05 0x1b088
MX6UL_PAD_CSI_DATA04__CSI_DATA06 0x1b088
MX6UL_PAD_CSI_DATA05__CSI_DATA07 0x1b088
MX6UL_PAD_CSI_DATA06__CSI_DATA08 0x1b088
MX6UL_PAD_CSI_DATA07__CSI_DATA09 0x1b088
};details from .config
# Video4Linux options
CONFIG_VIDEO_V4L2_I2C=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_V4L2_JPEG_HELPER=m
CONFIG_V4L2_MEM2MEM_DEV=y
CONFIG_V4L2_FWNODE=y
CONFIG_V4L2_ASYNC=y
CONFIG_V4L2_CCI=m
CONFIG_V4L2_CCI_I2C=m
CONFIG_VIDEOBUF_GEN=y
CONFIG_VIDEOBUF_DMA_CONTIG=y
# end of Video4Linux options
# MXC Camera/V4L2 PRP Features support
CONFIG_VIDEO_MXC_IPU_CAMERA=y
CONFIG_MXC_CAMERA_OV5640=m
CONFIG_MXC_CAMERA_OV5640_V2=y
# CONFIG_MXC_CAMERA_OV5642 is not set
CONFIG_MXC_CAMERA_OV5640_MIPI=m
CONFIG_MXC_CAMERA_OV5640_MIPI_V2=m
# CONFIG_MXC_CAMERA_OV5647_MIPI is not set
CONFIG_MXC_TVIN_ADV7180=m
CONFIG_MXC_IPU_DEVICE_QUEUE_SDC=y
# CONFIG_MXC_IPU_PRP_VF_SDC is not set
CONFIG_MXC_IPU_PRP_ENC=m
CONFIG_MXC_IPU_CSI_ENC=m
# end of MXC Camera/V4L2 PRP Features support
# CONFIG_VIDEO_MXC_OUTPUT is not set
CONFIG_VIDEO_MXC_PXP_V4L2=y
Solved! Go to Solution.
We switched from our dts file to the EVK dts and that revolved the MCLK issue. For anyone following this
1. We had missed out some nodes related to PXP in out DTS by mistake.
2. We had selected the wrong drivers under menuconfig as well.
Both of these resolved the issues mentioned under this topic.
Joanxie
After trying a few more things we are now at the following point.
root@imx6ul7d:~# gst-inspect-1.0 imxv4l2src====== IMXV4L2SRC: 4.9.0 build on May 8 2024 06:06:55. ======
Factory Details:
Rank primary + 1 (257)
Long-name IMX Video (video4linux2) Source
Klass Source/Video
Description Capture frames from IMX SoC video4linux2 device
Author Multimedia Team <shmmmw@freescale.com>
Plugin Details:
Name imxv4l2
Description IMX SoC v4l2-based video source/sink
Filename /usr/lib/gstreamer-1.0/libgstimxv4l2.so
Version 4.9.0
License LGPL
Source module imx-gst1.0-plugin
Binary package Freescle Gstreamer Multimedia Plugins
Origin URL http://www.freescale.com
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstPushSrc
+----GstImxV4l2Src
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw
format: YUY2
width: 640
height: 480
framerate: { (fraction)15/1, (fraction)30/1 }
video/x-raw
format: YUY2
width: 320
height: 240
video/x-raw
format: YUY2
width: 720
height: { (int)576, (int)480 }
Plugin Details:
Name imxv4l2
Version 4.9.0
License LGPL
GObject
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstPushSrc
+----GstImxV4l2Src
Pad Templates:
SRC template: 'src'
Capabilities:
video/x-raw
format: YUY2
width: 640
height: 480
video/x-raw
format: YUY2
width: 320
height: 240
video/x-raw
format: YUY2
width: 720
root@imx6ul7d:~# gst-inspect-1.0 | grep "imx"
imxcompositor: imxcompositor_pxp: IMX pxp Video Compositor
imxmp3enc: imxmp3enc: imx mp3 audio encoder
imxv4l2: imxv4l2sink: IMX Video (video4linux2) Sink
imxv4l2: imxv4l2src: IMX Video (video4linux2) Source
imxvideoconvert: imxvideoconvert_pxp: IMX pxp Video Converter
root@imx6ul7d:~# gst-launch-1.0 imxv4l2src device=/dev/video0 imx-capture-mode=0 num-buffers=1 ! 'video/x-raw,format=YUY2' ! jpegenc ! filesink location=test.jpg
WARNING: erroneous pipeline: no property "imx-capture-mode" in element "imxv4l2src"
root@imx6ul7d:~# v4l2-ctl --list-devices
i.MX6S_CSI (platform:21c4000.csi):
/dev/video0
From what I read else where we should have the following as well, but we dont have this.
pxp (pxp_v4l2_out):
/dev/video0
Can you please help with this, on what we might be missing.
if your customize board design is based on nxp imx6ull board, suggest that you can refer to the dts as below
https://github.com/nxp-imx/linux-imx/blob/lf-6.6.y/arch/arm/boot/dts/nxp/imx/imx6ul-14x14-evk.dtsi
ov5640: ov5640@3c {
compatible = "ovti,ov5640";
reg = <0x3c>;
pinctrl-0 = <&pinctrl_csi1 &pinctrl_camera_clock>;
pwn-gpios = <&gpio_spi 6 1>;
rst-gpios = <&gpio_spi 5 0>;
csi_id = <0>;
mclk = <24000000>;
mclk_source = <0>;
status = "disabled";
port {
&iomuxc {
pinctrl_camera_clock: cameraclockgrp {
fsl,pins = <
MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088
Joanxie,
I had tried this earlier, but on your recommendation I will try this again.
After making a few changes I got to a point where I am seeing this at the terminal
root@imx6ul7d:~# dmesg | grep -i "ov5640"
[ 2.226553] ov5640 1-003c: supply DOVDD not found, using dummy regulator
[ 2.234002] ov5640 1-003c: supply AVDD not found, using dummy regulator
[ 2.240942] ov5640 1-003c: supply DVDD not found, using dummy regulator
[ 2.285179] CSI: Registered sensor subdevice: ov5640 1-003c
[ 2.291800] Error: Driver 'ov5640' is already registered, aborting...
My assumption is my menuconfig is wrong? Can you help me resolve this?
firstly you need fix mclk issue, if ov5640 couldn't get mclk, for menuconfig, you can use "bitbake -c menuconfig linux-imx" to check if you choose the ov5640 correct or not, for more detailed information, pls refer to the linux referece manual
We ended up giving a external 20Mhz clock as we had a external 20 Mhz clock. Now we are able to see that the I2C communication is happening fine, but still we are seeing as below. Any pointers on how we can go about fixing this?
root@imx6ul7d:~# v4l2-ctl --device=/dev/video0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
root@imx6ul7d:~# v4l2-ctl -V --device=/dev/video0
Format Video Capture:
Width/Height : 0/0
Pixel Format : ''
Field : Any
Bytes per Line : 0
Size Image : 0
Colorspace : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
pls attach the logfile
Pls check the ov5640 data sheet if the 20Mhz is acceptable mclk for ov5640, normally we use 24M as Mclk, if still failed, pls share the logfile with me
