OV5640 and NTSC camera integration (using ADV7280AWBCPZ-M) in MIPI CSI line of IMX8MM EVK
1,030件の閲覧回数
Kaushal_Verma
Hi Community,
I am trying to integrate OV5640 sensor and NTSC camera using ADV7280AWBCPZ-M convertor then PI3WVR626XEBEX MIPI switch to select MIPI CSI input of IMX8MM EVK running on Android 11 OS. If you have any documentation or reference please provide. Main concern is switching camera input in runtime.
1,002件の閲覧回数
jimmychan
I think you need to porting the drivers. It is better to test it on Linux kernel first.
You can get the documentation of Linux BSP from here
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
i.MX Linux Reference Manual​ is the details of the drivers in kernel.
