OP-TEE Support on i.MX8M Mini
pierrelouis2
Can you please provide the steps to compile ATF with OP-TEE support for i.MX8M Mini?
make PLAT=imx8mm SPD=opteed bl31
When I compile with SPD=opteed it hangs between SPL and u-boot.
Regards.
Hi Anthony
for OP-TEE one can look at sect.5.6.10 OP-TEE enablement   i.MX Yocto Project User’s Guide​
Chapter 5  Configuring OP-TEE  i.MX Porting Guide
