Customer is aking how many times the same MCIMX6Q6AVT10AC can be "stressed" in a, already qualified, soldering reflow process?
Hi Darvin,
The reflow quantity is not indicated as is, but you could refer to the following application notes and supporting documents regarding reflow process on NXP products:
https://www.nxp.com/docs/en/supporting-information/Reflow_Soldering_Profile.pdf
https://www.nxp.com/files-static/microcontrollers/doc/app_note/AN3298.pdf
https://www.nxp.com/docs/en/application-note/AN10365.pdf
Hope this will be useful for you.
Best regards!
/Carlos
