Note: No wayland-egl support detected. Cross-toolkit compatibility disabled.
8,772 次查看
fulinux
   I am cross-compiling Qt5.9.1 with 4.1.15-2.1.0 toolchain,it shows build options:
Build options:
  Mode ................................... release
  Optimize release build for size ........ no
  Building shared libraries .............. yes
  Using C++ standard ..................... C++1z
  Using gold linker ...................... no
  Using new DTAGS ........................ no
  Using precompiled headers .............. no
  Using LTCG ............................. no
  Target compiler supports:
    NEON ................................. yes
  Build parts ............................ libs tools
Qt modules and options:
  Qt Concurrent .......................... yes
  Qt D-Bus ............................... yes
  Qt D-Bus directly linked to libdbus .... yes
  Qt Gui ................................. yes
  Qt Network ............................. yes
  Qt Sql ................................. yes
  Qt Testlib ............................. yes
  Qt Widgets ............................. yes
  Qt Xml ................................. yes
Support enabled for:
  Using pkg-config ....................... yes
  QML debugging .......................... yes
  udev ................................... yes
  Using system zlib ...................... yes
Qt Core:
  DoubleConversion ....................... yes
    Using system DoubleConversion ........ no
  GLib ................................... no
  iconv .................................. no
  ICU .................................... yes
  Logging backends:
    journald ............................. no
    syslog ............................... no
    slog2 ................................ no
  Using system PCRE2 ..................... no
Qt Network:
  getaddrinfo() .......................... yes
  getifaddrs() ........................... yes
  IPv6 ifname ............................ yes
  libproxy ............................... no
  OpenSSL ................................ yes
    Qt directly linked to OpenSSL ........ no
  SCTP ................................... no
  Use system proxies ..................... yes
Qt Gui:
  Accessibility .......................... yes
  FreeType ............................... yes
    Using system FreeType ................ yes
  HarfBuzz ............................... yes
    Using system HarfBuzz ................ yes
  Fontconfig ............................. yes
  Image formats:
    GIF .................................. yes
    ICO .................................. yes
    JPEG ................................. yes
      Using system libjpeg ............... yes
    PNG .................................. yes
      Using system libpng ................ yes
  EGL .................................... yes
  OpenVG ................................. no
  OpenGL:
    Desktop OpenGL ....................... no
    OpenGL ES 2.0 ........................ yes
    OpenGL ES 3.0 ........................ yes
    OpenGL ES 3.1 ........................ no
  Session Management ..................... no
Features used by QPA backends:
  evdev .................................. yes
  libinput ............................... no
  INTEGRITY HID .......................... no
  mtdev .................................. no
  tslib .................................. no
  xkbcommon-evdev ........................ no
QPA backends:
  DirectFB ............................... no
  EGLFS .................................. yes
  EGLFS details:
    EGLFS i.Mx6 .......................... yes
    EGLFS i.Mx6 Wayland .................. yes
    EGLFS EGLDevice ...................... no
    EGLFS GBM ............................ no
    EGLFS Mali ........................... no
    EGLFS Raspberry Pi ................... no
    EGL on X11 ........................... no
  LinuxFB ................................ yes
  VNC .................................... yes
  Mir client ............................. no
Qt Widgets:
  GTK+ ................................... no
  Styles ................................. Fusion Windows
Qt PrintSupport:
  CUPS ................................... no
Qt Sql:
  DB2 (IBM) .............................. no
  InterBase .............................. no
  MySql .................................. no
  OCI (Oracle) ........................... no
  ODBC ................................... no
  PostgreSQL ............................. no
  SQLite2 ................................ no
  SQLite ................................. yes
    Using system provided SQLite ......... no
  TDS (Sybase) ........................... no
Qt SerialBus:
  Socket CAN ............................. yes
  Socket CAN FD .......................... yes
QtXmlPatterns:
  XML schema support ..................... yes
Qt QML:
  QML interpreter ........................ yes
  QML network support .................... yes
Qt Quick:
  Direct3D 12 ............................ no
  AnimatedImage item ..................... yes
  Canvas item ............................ yes
  Support for Qt Quick Designer .......... yes
  Flipable item .......................... yes
  GridView item .......................... yes
  ListView item .......................... yes
  Path support ........................... yes
  PathView item .......................... yes
  Positioner items ....................... yes
  ShaderEffect item ...................... yes
  Sprite item ............................ yes
Qt Gamepad:
  SDL2 ................................... no
Qt 3D:
  Assimp ................................. yes
  System Assimp .......................... no
  Output Qt3D Job traces ................. no
  Output Qt3D GL traces .................. no
Qt 3D GeometryLoaders:
  Autodesk FBX ........................... no
Qt Wayland Drivers:
  EGL .................................... no
  Raspberry Pi ........................... no
  XComposite EGL ......................... no
  XComposite GLX ......................... no
  DRM EGL ................................ yes
  libhybris EGL .......................... no
Qt Wayland Client ........................ yes
Qt Wayland Compositor .................... yes
Qt Bluetooth:
  BlueZ .................................. yes
  BlueZ Low Energy ....................... yes
  Linux Crypto API ....................... yes
Qt Sensors:
  sensorfw ............................... no
Qt Multimedia:
  ALSA ................................... yes
  GStreamer 1.0 .......................... yes
  GStreamer 0.10 ......................... no
  Video for Linux ........................ yes
  OpenAL ................................. no
  PulseAudio ............................. yes
  Resource Policy (libresourceqt5) ....... no
  Windows Audio Services ................. no
  DirectShow ............................. no
  Windows Media Foundation ............... no
Qt Quick Controls 2:
  Styles ................................. Default Material Universal
Qt Quick Templates 2:
  Hover support .......................... yes
  Multi-touch support .................... yes
Qt Location:
  Gypsy GPS Daemon ....................... no
  WinRT Geolocation API .................. no
Qt WebEngine:
  Embedded build ......................... yes
  Pepper Plugins ......................... no
  Printing and PDF ....................... no
  Proprietary Codecs ..................... no
  Spellchecker ........................... yes
  WebRTC ................................. no
  Using system ninja ..................... yes
  System libraries:
    ICU .................................. no
    libwebp and libwebpdemux ............. yes
    Opus ................................. no
    ffmpeg ............................... no
Note: Also available for Linux: linux-clang linux-icc
Note: Dropped compiler flags '-pthread' when detecting library 'gstreamer'.
Note: Dropped compiler flags '-pthread' when detecting library 'gstreamer_app'.
Qt is now configured for building. Just run 'make'.
How can i enable wayland-egl option in the configure?
thanks.
fulinux.
标签 (1)
2 回复数
4,796 次查看
gusarambula
Hello Fulin Chen,
Have you found a fix to this error or do the problem remains? I couldn’t find other users with similar problems but it could be a problem with the libraries not being linked correctly. There is a document on this but it’s a bit old:
https://community.nxp.com/thread/305945
Perhaps it could help.
4,796 次查看
fulinux
thanks, i will be try.
