Not seeing Android Logo with imx6dl custom with android_p9.0.0_2.2.0
19,864 次查看
chpub70
Hi NXP,
I am using a android_p9.0.0_2.2.0 pre-built image, but I rebuilt the kernel + device tree, uboot for our custom board. The custom board is currently using kernel 4.9.11 Debian9. The code is porting from kernel 4.9.11. The custom board has 2 display 1368x768 and 800x480.
When bootup, I can see 1 penguin and debug message dump to the display. The debug message is the same as the one in COM 1 port.
I attach ps command, dmesg  and uboot log for your reference.
Pun
28 回复数
13,668 次查看
aravinthkumarja
Senior Contributor II
Hi @chpub70
Did you resolved this issue.?
Aravinth
16,521 次查看
chpub70
U-Boot 2018.03 (Aug 14 2020 - 12:56:54 +0800)
CPU: Freescale i.MX6SOLO rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 24C
Reset cause: POR
Model: Freescale i.MX6 DualLite SABRE Smart Device Board
Board: MX6-SabreSD
DRAM: 1 GiB
read error from device: 49f18f10 register: 0x0!read error from device: 49f18f10 register: 0x3!PMIC: PFUZE100! DEV_ID=0xfffffffb REV_ID=0xfffffffb
read error from device: 49f18f10 register: 0x21!write error to device: 49f18f10 register: 0x21!read error from device: 49f18f10 register: 0x24!write error to device: 49f18f10 register: 0x24!read error from device: 49f18f10 register: 0x2f!write error to device: 49f18f10 register: 0x2f!read error from device: 49f18f10 register: 0x32!write error to device: 49f18f10 register: 0x32!read error from device: 49f18f10 register: 0x0!Not supported, id=11
initcall sequence 4ff9f098 failed at call 17804ca8 (err=-22)
### ERROR ### Please RESET the board ###
U-Boot 2018.03-dirty (Aug 14 2020 - 09:27:39 +0800)
BOOTLOADER_VER=33.1
CPU: Extended Commercial temperature grade (-20C to 105C) at 26C
Reset cause: POR
Board: MX6-SabreSD
DRAM: tws: ctls=83190000, misc=40081740
512 MiB
start of tws_gpio_init
no usb boot support
usb boot is low
power_init_board(), bypass
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... board_mmc_get_env_dev(), devno=1
mmc_start_init(), no_card=1
*** Warning - bad CRC, using default environment
Failed (-5)
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
flash target is MMC:0
Net: No ethernet found.
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
RNG already instantiated 0x40000003
Error: blob decap job failed 0x2000081a
Error during blob decap operation: 0x2000081a
In boota get fastboot lock status error. Set lock status
verify OK, boot 'boot'
kernel @ 14008000 (10181704)
ramdisk @ 15000000 (1835263)
fdt @ 14f00000 (55391)
## Booting Android Image at 0x14007800 ...
Kernel load addr 0x14008000 size 9944 KiB
## Flattened Device Tree blob at 14f00000
Booting using the fdt blob at 0x14f00000
XIP Kernel Image ... OK
Using Device Tree in place at 14f00000, end 14f1085e
tws: ldo_mode_set() @CONFIG_DM_PMIC_PFUZE100, ldo_bypass=1
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.14.98 (tws@ubuntu) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #1 SMP PREEMPT Fri Aug 14 13:04:26 +08 2020
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Freescale i.MX6 DualLite SABRE Smart Device Board
Memory policy: Data cache writeback
cma: Reserved 320 MiB at 0x1c000000
CPU: All CPU(s) started in SVC mode.
random: get_random_bytes called from start_kernel+0xac/0x450 with crng_init=0
percpu: Embedded 18 pages/cpu @cba8b000 s41292 r8192 d24244 u73728
Built 1 zonelists, mobility grouping on. Total pages: 129920
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug androidboot.serialno=2b1aa1d4eacb3786 androidboot.btmacaddr=2b:1a:a1:d4:ea:cb androidboot.soc_type=imx6dl androidboot.storage_type=sd gpt androidboot.boottime=1BLL:0,1BLE:2644,KL:0,KD:0,AVB:1220,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix= androidboot.vbmeta.device=PARTUUID=e5f1ccc3-46f5-4043-996e-a47049fce741 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=locked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=2944 androidboot.vbmeta.digest=cf0736384d0970f24ca719655a71016ad7732537aaa0df242d2ce33a32a01210 androidboot.veritymode=enforcing androidboot.dtbo_idx=0 androidboot.key
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 167732K/524288K available (13312K kernel code, 1057K rwdata, 4052K rodata, 1024K init, 504K bss, 28876K reserved, 327680K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0e00000 (14304 kB)
.init : 0xc1300000 - 0xc1400000 (1024 kB)
.data : 0xc1400000 - 0xc1508550 (1058 kB)
.bss : 0xc150a000 - 0xc1588348 ( 505 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
ftrace: allocating 41814 entries in 123 pages
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Tasks RCU enabled.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Security Framework initialized
SELinux: Initializing.
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU0: Spectre v2: using BPIALL workaround
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100060
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
smp: Brought up 1 node, 1 CPU
SMP: Total of 1 processors activated (6.00 BogoMIPS).
CPU0: update max cpu_capacity 1024
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6DL, silicon rev 1.3
vdd1p1: supplied by regulator-dummy
vdd3p0: supplied by regulator-dummy
vdd2p5: supplied by regulator-dummy
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6dl-pinctrl 20e0000.iomuxc: Invalid fsl,pins or pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/gpio_leds/gpioledsgrp
imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx rpmsg driver is registered.
pstore: using zlib compression
console [pstore-1] enabled
pstore: Registered ramoops as persistent store backend
ramoops: attached 0x100000@0x3ff00000, ecc: 0/0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usb_phy_generic 2000000.aips-bus:usbphy_nop1: 2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
usb_phy_generic 2000000.aips-bus:usbphy_nop2: 2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA, using PIO instead.
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
i2c i2c-2: Max17135 PMIC not found!
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA, using PIO instead.
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 1796K
hw perfevents: no interrupt-affinity property for /soc/pmu, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.590:1): state=initialized audit_enabled=0 res=1
workingset: timestamp_bits=14 max_order=17 bucket_order=3
Registering sdcardfs 0.1
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.26)
io scheduler noop registered
io scheduler mq-deadline registered
io scheduler kyber registered
pwm-backlight backlight: backlight supply power not found, using dummy regulator
mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
mxc_sdc_fb fb@0: registered mxc display driver ldb
imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb fb@1: Can't get fb option for mxcfb1!
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: Falling back to user helper
mxs-dma 110000.dma-apbh: initialized
imx-pgc-pd imx-pgc-power-domain.0: Linked as a consumer to 20dc000.gpc
pfuze100-regulator 1-0008: unrecognized pfuze chip ID!
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 26, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 76, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized vivante 1.0.0 20120216 for platform:Vivante GCCore on minor 0
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
zram: Added device: zram0
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
CAN device driver interface
fec 2188000.ethernet: 2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 9e:35:23:ca:79:53
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
usbcore: registered new interface driver kaweth
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb_ehset_test
usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
egalax_ts 1-0004: Failed to switch to I2C interface
egalax_ts 2-0004: Failed to switch to I2C interface
input: max11801_ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0048/input/input2
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-rtc-lp as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
ov564x 0-003c: cannot get io voltage
ov564x 0-003c: cannot get core voltage
ov564x 0-003c: cannot get analog voltage
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
ov5642_power_on: cannot get io voltage error
ov5642_power_on: cannot get core voltage error
ov5642_power_on: cannot get analog voltage error
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
ov5640_power_on: cannot get io voltage error
ov5640_power_on: cannot get core voltage error
ov5640_power_on: cannot get analog voltage error
camera ov5640_mipi is not found
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
__power_supply_register: Expected proper parent device for 'battery'
(NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
__power_supply_register: Expected proper parent device for 'usb'
mag3110 2-000e: check mag3110 chip ID
mag3110 2-000e: read chip ID 0xfffffffa is not equal to 0xc4!
mag3110: probe of 2-000e failed with error -22
mma8x5x 0-001c: read chip ID 0xfffffffa is not equal to 0x1a,0x2a,0x3a,0x4a,0x5a!
mma8x5x: probe of 0-001c failed with error -22
imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
bt power gpio is:2
rfkill: BT RF going to : on
mxc_bt_rfkill_reset
mxc_bt_rfkill driver success loaded
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2194000.usdhc: allocated mmc-pwrseq
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
mmc1: host does not support reading read-only switch, assuming write-enable
mmc1: new high speed SDHC card at address 5048
mmcblk1: mmc1:5048 SD08G 7.41 GiB
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Primary GPT is invalid, using alternate GPT.
mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
wm8962 0-001a: Failed to read ID register
fsl-ssi-dai 202c000.ssi: No cache defaults, reading back from HW
fsl-hdmi-dai soc:hdmi_audio@00120000: failed to probe. Load HDMI-video first.
fsl-hdmi-dai: probe of soc:hdmi_audio@00120000 failed with error -12
imx-wm8962 sound: failed to find codec platform device
imx-wm8962: probe of sound failed with error -22
imx-audio-hdmi sound-hdmi: initialize HDMI-audio failed. load HDMI-video first!
NET: Registered protocol family 26
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
IPv4 over IPsec tunneling driver
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
Segment Routing with IPv6
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20170425 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20170425) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
lib80211: common routines for IEEE802.11 drivers
registered taskstats version 1
imx_epdc_fb 20f4000.epdc: Unable to get display PMIC regulator.err = 0xfffffdfb
input: gpio-keys as /devices/soc0/gpio-keys/input/input3
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:06 UTC (6)
usb_otg_vbus: disabling
usb_h1_vbus: disabling
wm8962-supply: disabling
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 1024K
init: init first stage started!
init: Using Android DT directory /proc/device-tree/firmware/android/
init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
init: bool android::init::FirstStageMount::InitRequiredDevices(): partition(s) not found in /sys, waiting for their uevent(s): boot, system, vbmeta, vendor
random: fast init done
init: Wait for partitions returned after 10010ms
init: bool android::init::FirstStageMount::InitRequiredDevices(): partition(s) not found after polling timeout: boot, system, vbmeta, vendor
init: Failed to mount required partitions early ...
init: Reboot start, reason: reboot, rebootTarget: bootloader
init: Reboot ending, jumping to kernel
imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
reboot: Restarting system with command 'bootloader'
imx2-wdt 20c0000.wdog: failed to assert external reset, trying with timeout
Reboot failed -- System halted
BOOTLOADER_VER=33.1
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
avb_slot_verify.c:388: ERROR: dtbo: Hash of data does not match digest in descriptor.
fdt @ 14f00000 (49468)
Using Device Tree in place at 14f00000, end 14f0f13b
Starting kernel ...
OF: fdt: Machine model: TWS IPT370P
percpu: Embedded 18 pages/cpu @cba8e000 s41292 r8192 d24244 u73728
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug androidboot.serialno=2b1aa1d4eacb3786 androidboot.btmacaddr=2b:1a:a1:d4:ea:cb androidboot.soc_type=imx6dl androidboot.storage_type=sd gpt androidboot.boottime=1BLL:0,1BLE:2616,KL:0,KD:0,AVB:1233,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix= androidboot.vbmeta.device=PARTUUID=e5f1ccc3-46f5-4043-996e-a47049fce741 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=locked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=2944 androidboot.vbmeta.digest=cf0736384d0970f24ca719655a71016ad7732537aaa0df242d2ce33a32a01210 androidboot.veritymode=enforcing androidboot.dtbo_idx=0 androidboot.key
Memory: 167748K/524288K available (13312K kernel code, 1057K rwdata, 4052K rodata, 1024K init, 504K bss, 28860K reserved, 327680K cma-reserved, 0K highmem)
Tasks RCU enabled.
gpio-regulator regulator-gpio: Failed to allocate supply name
imx6dl-pinctrl 20e0000.iomuxc: not freeing pin 78 (MX6DL_PAD_EIM_BCLK) as part of deactivating group twsgrp - it is already used for some other setting
imx6dl-pinctrl 20e0000.iomuxc: not freeing pin 120 (MX6DL_PAD_EIM_WAIT) as part of deactivating group twsgrp - it is already used for some other setting
imx6dl-pinctrl 20e0000.iomuxc: not freeing pin 88 (MX6DL_PAD_EIM_D23) as part of deactivating group twsgrp - it is already used for some other setting
gpio-regulator: probe of regulator-gpio failed with error -12
audit: type=2000 audit(0.570:1): state=initialized audit_enabled=0 res=1
Console: switching to colour frame buffer device 100x30
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 25, base_baud = 5000000) is a IMX
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 68, base_baud = 5000000) is a IMX
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 69, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 70, base_baud = 5000000) is a IMX
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 71, base_baud = 5000000) is a IMX
brd: module loaded
loop: module loaded
imx_usb 2184000.usb: 2184000.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.14.98 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
imx_usb 2184200.usb: 2184200.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 4.14.98 ehci_hcd
usb usb2: SerialNumber: ci_hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
bt power gpio is:2
mxc_bt_rfkill_reset
usb 1-1: new high-speed USB device number 2 using ci_hdrc
mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address 5048
mmcblk0: mmc0:5048 SD08G 7.41 GiB
mmc1: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
mmc2: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
ashmem: initialized
usb 1-1: New USB device found, idVendor=0409, idProduct=005a
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
u32 classifier
Actions configured
mip6: Mobile IPv6
imx_epdc_fb 20f4000.epdc: can't get/select pinctrl
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:05 UTC (5)
sensor-supply: disabling
hdmi-5v-supply: disabling
mipi_dsi_pwr_on: disabling
ALSA device list:
init: [libfs_mgr]Returning avb_handle with status: 0
init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/soc0/soc/2100000.aips-bus/2194000.usdhc/by-name/system /dev/block/platform/soc0/soc/2100000.aips-bus/2194000.usdhc/by-name/system 4096 4096 451493 451493 sha1 665ccefca605b0cbbf1b5c36dccd59f03a118519 992586750c732bb2a68e1171ca0a1ca8d87d80e7 10 use_fec_from_device /dev/block/platform/soc0/soc/2100000.aips-bus/2194000.usdhc/by-name/system fec_roots 2 fec_blocks 455050 fec_start 455050 restart_on_corruption ignore_zero_blocks'
EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
init: [libfs_mgr]__mount(source=/dev/block/dm-0,target=/system,type=ext4)=0: Success
init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/soc0/soc/2100000.aips-bus/2194000.usdhc/by-name/vendor /dev/block/platform/soc0/soc/2100000.aips-bus/2194000.usdhc/by-name/vendor 4096 4096 28199 28199 sha1 58806b8b3b7c3d0643ff4669e7434541d3eb9ca2 406433c5dcf12f7c351627661a06f39dbbdf4541 10 use_fec_from_device /dev/block/platform/soc0/soc/2100000.aips-bus/2194000.usdhc/by-name/vendor fec_roots 2 fec_blocks 28423 fec_start 28423 restart_on_corruption ignore_zero_blocks'
EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
init: Loading SELinux policy
SELinux: Class process2 not defined in policy.
SELinux: Class infiniband_pkey not defined in policy.
SELinux: Class infiniband_endport not defined in policy.
SELinux: the above unknown classes and permissions will be denied
SELinux: policy capability network_peer_controls=1
SELinux: policy capability open_perms=1
SELinux: policy capability extended_socket_class=1
SELinux: policy capability always_check_network=0
SELinux: policy capability cgroup_seclabel=0
SELinux: policy capability nnp_nosuid_transition=0
audit: type=1403 audit(6.400:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(6.400:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: 2 output lines suppressed due to ratelimiting
init: init second stage started!
selinux: SELinux: Loaded file_contexts
init: Running restorecon...
init: waitid failed: No child processes
init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
init: Forked subcontext for 'u:r:vendor_init:s0' with pid 137
init: Forked subcontext for 'u:r:vendor_init:s0' with pid 138
init: Parsing file /init.rc...
audit: type=1400 audit(6.790:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: ueventd started!
audit: type=1400 audit(6.800:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: Parsing file /ueventd.rc...
audit: type=1400 audit(6.800:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(6.800:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: Parsing file /vendor/ueventd.rc...
audit: type=1400 audit(6.810:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(6.810:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: Parsing file /odm/ueventd.rc...
audit: type=1400 audit(6.810:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
ueventd: Parsing file /ueventd.freescale.rc...
ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
ueventd: firmware: loading 'imx/sdma/sdma-imx6q.bin' for '/devices/soc0/soc/2000000.aips-bus/20ec000.sdma/firmware/imx!sdma!sdma-imx6q.bin'
ueventd: loading /devices/soc0/soc/2000000.aips-bus/20ec000.sdma/firmware/imx!sdma!sdma-imx6q.bin took 72ms
imx-sdma 20ec000.sdma: loaded firmware 3.4
Console: switching to colour dummy device 80x30
watchdogd: watchdogd started (interval 10, margin 20)!
tune2fs: tune2fs 1.43.3 (04-Sep-2016)
tune2fs: /system/bin/tune2fs: Permission denied while trying to open /dev/block/by-name/userdata
tune2fs: Couldn't find valid filesystem superblock.
tune2fs: tune2fs terminated by exit(1)
EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
e2fsck: e2fsck 1.43.3 (04-Sep-2016)
e2fsck: /system/bin/e2fsck: Permission denied while trying to open /dev/block/by-name/userdata
e2fsck: You must have r/w access to the filesystem or be root
e2fsck: e2fsck terminated by exit(8)
mmc1: error -110 whilst initialising MMC card
EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
EXT4-fs (mmcblk0p5): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
init: 6 output lines suppressed due to ratelimiting
kauditd_printk_skb: 28 callbacks suppressed
audit: type=1400 audit(8.480:39): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(8.480:40): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(8.480:41): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
zram0: detected capacity change from 0 to 536870912
audit: type=1400 audit(8.480:42): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(8.530:43): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(8.530:44): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(8.530:45): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
mkswap: Swapspace size: 524284k, UUID=1411b031-063e-423b-babd-7ab3c247d7d6
Adding 524284k swap on /dev/block/zram0. Priority:-2 extents:1 across:524284k SS
audit: type=1400 audit(8.550:46): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(8.550:47): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
logd.auditd: start
audit: type=1400 audit(8.560:48): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
type=1400 audit(9.810:64): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ci_hdrc ci_hdrc.1: remove, state 4
usb usb2: USB disconnect, device number 1
ci_hdrc ci_hdrc.1: USB bus 2 deregistered
ci_hdrc ci_hdrc.0: remove, state 4
usb usb1: USB disconnect, device number 1
usb 1-1: USB disconnect, device number 2
ci_hdrc ci_hdrc.0: USB bus 1 deregistered
imx2-wdt 20bc000.wdog: Device shutdown: Expect reboot!
reboot: Restarting system with command 'recovery'
BOOTLOADER_VER=33.1
CPU: Extended Commercial temperature grade (-20C to 105C) at 30C
Reset cause: WDOG
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Got Recovery key pressing or recovery commands!
setup env for recovery..
Normal Boot
Will boot from recovery!
verify OK, boot 'recovery'
ramdisk @ 15000000 (6254320)
Starting kernel ...
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug androidboot.serialno=2b1aa1d4eacb3786 androidboot.btmacaddr=2b:1a:a1:d4:ea:cb androidboot.soc_type=imx6dl androidboot.storage_type=sd gpt androidboot.boottime=1BLL:0,1BLE:3049,KL:0,KD:0,AVB:1635,ODT:0,SW:0 androidboot.bootreason=watchdog androidboot.verifiedbootstate=green androidboot.slot_suffix= androidboot.vbmeta.device=PARTUUID=e5f1ccc3-46f5-4043-996e-a47049fce741 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=locked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=2944 androidboot.vbmeta.digest=cf0736384d0970f24ca719655a71016ad7732537aaa0df242d2ce33a32a01210 androidboot.veritymode=enforcing androidboot.dtbo_idx=0 androidboot.keystore
Memory: 163420K/524288K available (13312K kernel code, 1057K rwdata, 4052K rodata, 1024K init, 504K bss, 33188K reserved, 327680K cma-reserved, 0K highmem)
Tasks RCU enabled.
BOOTLOADER_VER=33.1
CPU: Extended Commercial temperature grade (-20C to 105C) at 25C
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
boota: bad dt table magic d00dfeed
g_dnl_register: failed!, error: -19
BOOTLOADER_VER=33.1
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
Starting kernel ...
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug androidboot.serialno=2b1aa1d4eacb3786 androidboot.btmacaddr=2b:1a:a1:d4:ea:cb androidboot.soc_type=imx6dl androidboot.storage_type=sd gpt androidboot.boottime=1BLL:0,1BLE:2614,KL:0,KD:0,AVB:1229,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix= androidboot.vbmeta.device=PARTUUID=e5f1ccc3-46f5-4043-996e-a47049fce741 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=locked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=2944 androidboot.vbmeta.digest=cf0736384d0970f24ca719655a71016ad7732537aaa0df242d2ce33a32a01210 androidboot.veritymode=enforcing androidboot.dtbo_idx=0 androidboot.key
Tasks RCU enabled.
brd: module loaded
loop: module loaded
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 72:2a:88:18:c5:78
bt power gpio is:2
mxc_bt_rfkill_reset
ashmem: initialized
u32 classifier
Actions configured
mip6: Mobile IPv6
ALSA device list:
audit: type=1403 audit(7.390:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(7.390:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: Forked subcontext for 'u:r:vendor_init:s0' with pid 136
audit: type=1400 audit(7.780:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(7.800:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(7.800:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(7.800:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(7.830:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(7.830:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(7.830:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: loading /devices/soc0/soc/2000000.aips-bus/20ec000.sdma/firmware/imx!sdma!sdma-imx6q.bin took 78ms
kauditd_printk_skb: 6 callbacks suppressed
audit: type=1400 audit(8.990:17): avc: denied { read write } for pid=148 comm="tune2fs" name="mmcblk1p11" dev="tmpfs" ino=9508 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=0
EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
audit: type=1400 audit(9.160:18): avc: denied { read } for pid=152 comm="e2fsck" name="mmcblk1p11" dev="tmpfs" ino=9508 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=0
audit: type=1400 audit(9.190:19): avc: denied { read write } for pid=152 comm="e2fsck" name="mmcblk1p11" dev="tmpfs" ino=9508 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=0
audit: type=1400 audit(9.270:20): avc: denied { read write } for pid=153 comm="tune2fs" name="mmcblk1p11" dev="tmpfs" ino=9508 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=0
audit: type=1400 audit(9.350:21): avc: denied { read write } for pid=154 comm="tune2fs" name="mmcblk1p11" dev="tmpfs" ino=9508 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=0
EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
EXT4-fs (mmcblk1p5): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
audit: type=1400 audit(9.480:22): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(9.500:23): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(9.500:24): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(9.500:25): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(9.500:26): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
mkswap: Swapspace size: 524284k, UUID=d97da870-1e48-4200-89d0-51a26a7ab2b2
logd.auditd: start
type=1400 audit(10.020:54): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
imx2-wdt 20c0000.wdog: Device shutdown: Expect reboot!
Reset cause: POR
Board: MX6-SabreSD
DRAM: 1 GiB
BOOTLOADER_VER=33.1
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
Starting kernel ...
Tasks RCU enabled.
brd: module loaded
loop: module loaded
bt power gpio is:2
mxc_bt_rfkill_reset
ashmem: initialized
u32 classifier
Actions configured
mip6: Mobile IPv6
ALSA device list:
BOOTLOADER_VER=33.1
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
Starting kernel ...
Tasks RCU enabled.
brd: module loaded
loop: module loaded
bt power gpio is:2
mxc_bt_rfkill_reset
ashmem: initialized
u32 classifier
Actions configured
mip6: Mobile IPv6
ALSA device list:
logd.auditd: start
BOOTLOADER_VER=33.1
Reset cause: WDOG
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Normal Boot
Starting kernel ...
Tasks RCU enabled.
BOOTLOADER_VER=33.1
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
BOOTLOADER_VER=33.1
Reset cause: POR
Board: MX6-SabreSD
512 MiB
no usb boot support
usb boot is low
Failed (-5)
In: serial
Out: serial
Err: serial
Fastboot: Normal
Normal Boot
Starting kernel ...
Tasks RCU enabled.
brd: module loaded
loop: module loaded
bt power gpio is:2
mxc_bt_rfkill_reset
ashmem: initialized
u32 classifier
Actions configured
mip6: Mobile IPv6
ALSA device list:
logd.auditd: start
16,521 次查看
weidong_sun
Hello Chee,
Could you send schematic to me?
or
show schematic of PMIC and I2C here?
Thanks!
Have a nice day!
Weidong
16,507 次查看
chpub70
Hi NXP,
I attached the i2c and pmic schematic. The pmic is using i2c4 which is connected to the imx6dl, which is used to program the pmic using external tool.
Pun
16,500 次查看
chpub70
Hi NXP,
Correction.
The pmic is using i2c4 which is NOT connected to the imx6dl as in the schmatic.
16,469 次查看
chpub70
Hi @weidong_sun and @Zhiming_Liu ,
The pmic in our custom board is not  controllable by imx6. The i2c4 is used to program the PMIC via external tool.
Do you have a workaround so that without PMIC being controlled by imx6, the Android will bootup correctly ? For example, how to provide read and set voltage example for GPU/VPU so that it can run properly.
@chpub70
16,506 次查看
chpub70
When I build kernel alone, I add a config to Kconfig and use make menuconfig to select the config so that to see it .config.
May I know how to do add a config item in kernel if I am build the entire system ?
Thank You in advance,
16,506 次查看
Zhiming_Liu
Dear  Chee Huey Pun
You can add your config in our defconfig file so that you can build entire system.
Zhiming
16,506 次查看
chpub70
Hi NXP,
I have changed various Kconfig files and then I use make menuconfig to generate the .config. Can I use .config file as default config by just replace the default file with .config ?
Thank You in advance.
16,506 次查看
Zhiming_Liu
Hi Chee Huey Pun
Of course,you can do that.
Zhiming
16,506 次查看
chpub70
Hi Zhiming,
I have rebuilt the system without modification, but burning to my board cause uboot cannot start up. So I burned my  uboot image(using correct ddr file, some modifications to bypass regulator and SD card detection that I built last time) and can boot up into uboot.
Then kernel stuck at mount system and vendor due to sd card slot in device tree is not the same as my board. My board  need 2194. So I converted dtbo.img -> dtb -> dts, then I updated the dts. Then I converted it back to dtbo.img and flash to my sd card. Can see mounting but see reboot caused by recovery. No actual reboot due to watchdog is not correct.
I re-used device tree for my board that use Debian and added in firmware node { and then I flashed in to the sd card, then see reboot caused by recovery and got reboot because this is with correct watchdog.
I have attached the log.
Please advise, why there is recovery reboot.
Pun
16,506 次查看
Zhiming_Liu
Hi Chee Huey Pun
Can you give me the steps that you burn image and your bootargs in uboot ?
Zhiming
16,506 次查看
chpub70
Hi Zhiming,
Sorry for the late reply.
Burn SD card image
- sudo ./fsl-sdcard-partition.sh -f imx6dl /dev/sdb
setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug
- this cause recovery reboot. This is the one from pre-built image, I think it is added to boot.img
if I clear the bootargs, there is no recovery reboot but I will have the errors that you see in the log. And there is no Android logo.
Pun
16,505 次查看
chpub70
Hi Zhiming,
After I did setenv bootargs console=ttymxc0,115200 init=/init so that not to use the command line included in the boot.img, the machine can boot up to login prompt.
I have attached the dmesg and logcat log for your reference.
Pun
16,505 次查看
Zhiming_Liu
Hi Chee Huey Pun,
[ 0.282076] i2c i2c-0: IMX I2C adapter registered
[ 0.282099] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.283424] i2c i2c-1: IMX I2C adapter registered
[ 0.283446] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.299790] i2c i2c-2: Max17135 PMIC not found!
[ 0.299978] i2c i2c-2: IMX I2C adapter registered
[ 0.299999] i2c i2c-2: can't use DMA, using PIO instead.
[ 1.794146] egalax_ts 1-0004: Failed to switch to I2C interface
[ 1.799328] egalax_ts 2-0004: Failed to switch to I2C interface
[ 2.490246] mag3110 2-000e: check mag3110 chip ID
[ 2.494062] mag3110 2-000e: read chip ID 0xfffffffa is not equal to 0xc4!
[ 2.499806] mag3110: probe of 2-000e failed with error -22
[ 2.504988] mma8x5x 0-001c: read chip ID 0xfffffffa is not equal to 0x1a,0x2a,0x3a,0x4a,0x5a!
[ 2.512530] mma8x5x: probe of 0-001c failed with error -22
Your IIC have some problems and it can not read messages from PMIC and you can try wit my two suggestions below.
1.In software, see your dts file and check if you use default i2c pin mux in other dts node.You mentinoned that you changed your dts. It may cause the iic was set incorretcly so can not work with PMIC.You can use common gpio to simulate iic function test your board.
2.In hardware,you can check if your iic io have Pull-up resistors in your Schematic diagram and decrease the iic speed to 10k use logic analyzer  to see the IIC waveform.
Zhiming
16,505 次查看
chpub70
Hi Zhiming,
My board does not use the same pmic. The pmic is not part of device tree as the voltage is fixed. My board only has our own i2c devices such as external RTC chip. I defined this in device tree and also add in the driver.
There is no problem when running debian but the kernel config has removed almost all the unnecessary devices. However for the Android, I have not done the clean up.
What is your suggestion ?
Pun
16,505 次查看
chpub70
Hi Zhiming,
The uboot is working fine now because I have ported our working uboot that used in my board(product) currently running debian. The uboot will bypass pmic.
Can I send you my device tree, we only use these i2C devices ? I can also remove these error devices  from config.
16,505 次查看
chpub70
Hi Zhiming and Waidong,
See attached dmesg log and also device tree files.
bootargs=console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug cma=320M
My board is using i2c0, this is an external RTC chip. Not I did not see the i2c error.
This boot.img is not integrated with the display stuffs, so cannot see anything on display.
Please help to take a look. Meanwhile, I will integrate the display stuff and check.
Thank you in advance.
Pun
16,505 次查看
chpub70
Hi NXP,
May I know why adding "androidboot.hardware" in command line will cause recovery reboot. ?
I have integrated the display stuff, but I can only see penguin logo, but not android logo, also no menu.
Please help and advise.
Pun
16,505 次查看
chpub70
