Not able to logged in as root (MCIMX28EVK)
pt
Senior Contributor I
Evaluation kit: MCIMX28EVK.
Linux BSP    : Linux2.6.35
I am able port linux2.3.5 bsp on imx28 EVK board via sd card.
But I am not able to get into root login.
How to solve this issue?
The message log is attached here ...
pt
     bad usb to serial converter. so data was not sending to board .that is why this issue caused.
pt
jamesbone
alejandrolozano, can you please comment?
pt
solved the issue
alejandrolozan1
Would you be nice enough to share the solution?
Alejandro
pt
pt
