Not able to build Soft ISP demo
1,475 次查看
Tong
I am trying NXP Soft ISP demo by following https://github.com/NXPmicro/gtec-demo-framework/blob/master/Doc/Setup_guide_yocto.md , but build fails.
First of all, I build SDK from source tree with following command, my source tree's target machine is i.MX8mn
bitbake image -c populate_sdk
then I install the SDK, and build Soft ISP demo:
. environment-setup-aarch64-poky-linux
cd ~/gtec-demo-framework
source
prepare.sh
cd DemoApps/OpenCL/SoftISP
FslBuild.py --Variants [WindowsSystem=Wayland]
The error is:
../../../../DemoFramework/FslDemoApp/Util/Graphics/source/FslDemoApp/Util/Graphics/Service/ImageLibrary/STBImageWriteLib.cpp:34:10: fatal error: stb_image_write.h: No such file or directory
34 | #include <stb_image_write.h>
What is wrong with my step and how to fix it?
Thanks.
1,460 次查看
joanxie
as I known, current bsp includes ISP demo already, I suggest that you can build yocto bsp directly, the demo under /opt/imx-gpu-sdk/OpenCL/SoftISP
1,461 次查看
joanxie
