Nor flash (MT25QU256ABA) in Imx8mp_evk protection error
Majidbahmani
Hope you are all well.
I want to read/write nor flash memory (MT25QU256ABA) in imx8mp_evk board. I can access all configuration registers and read memory but when I write to the nor flash memory It seems that It is not applied and when I check the flag status register I get 0x92 according to datasheet it seems that it is a protection error.
I run enable_write in the first step and I have also checked:
nonvolatile lock bit --> unlock,
Hold and WP pins --> High,
Global free bit --> unlock.
I didn't change anything in Protection Security Register and its value is 0xFF
Can anyone tell me how I can solve the problem?
Majid.
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Can you flash the
Burn bootimage into QSPI flash
uuu -b qspi qspi_bootloader
