No mobile/cellular setting page under Network & Internet
2,551 次查看
bensonwu
I am porting Android 8.0 on imx6dl with sabresd BSP provided by NXP.
Recently, I am porting USB 4G  LTE driver(Quectel) , however, I met a problem/issue related to UI.
Based on my existing experiences, the mobile network/Cellular (4G) setting page should be available at sub-page under Network & Internet no matter 3G/4G/LTE module is attached or not. However, I did not found that setting page.
Did anybody tell me how to make the setting available?
My UI
The UI is supposed to be as follows:
标签 (3)
2,175 次查看
bensonwu
Based on the information from this post Android8.1 BSP can't find mobile phone data network settings
I think I solved my problems.
My actions is as follows:
    • Comment out the followings configurations on name @device/fsl/sabresd_6de/overlay/frameworks/base/core/res/res/values/config.xml
      • networkAttributes
      • radioAttributes
  1. Modify ro.radio.noril=no @device/fsl/imx6/imx6.mk
2,176 次查看
bensonwu
      • networkAttributes
      • radioAttributes
2,175 次查看
igorpadykov
Hi Benson
one can look at common cellular modem guidelines
Cellular modems on i.MX6 boards under Ubuntu
In general modem vendor should provide documentation for its modem porting.
