No boot log on Monitor with SDCard booting with android images
1,453 次查看
himabindu
Hi Team,
        I am working on IMX8M EVK board. By default board is booting with EMMC android images.
I have flashed android images on to SDCard. Boot Mode Switch Setting is done for SDCard  boot up.
But with SDCard board is not booting and we are not getting any logs on the Monitor.
Procedure followed to format the sdcard is using mkpart   utility and made partition1 as vfat . After this
flashed android images using fsl-sdcard-partition.sh script. When sdcard is inserted into board, board is not booting.
Please we need your support to proceed .
Thanks & Regards,
C.Himabindu.
1,445 次查看
Hi himabindu
what board used in the case, EVK or custom board.
If EVK one can try to program SD using uuu tool and Demo Images
from link:
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
follow section Programming Images Android User's Guide included in documentation.
1,440 次查看
himabindu
Hi Team,
            After programming the EVK android images into sdcard board is not booting.
Any suggestion to identify why the board is not booting.
Thanks & Regards,
C.Himabindu.
1,422 次查看
please check what exact "IMX8M EVK board" board used in the case - Quad, Mini or Nano
below link shows which BSP release can be used for each board
right column "Supported Platforms/Demo Images​":
