No any response from SD boot using Android 4.4.3 BSP
次の代わりに検索
378件の閲覧回数
changyuheng
Hello~
As title, not only flash SD card using 4.4.3 BSP source code(use sudo ./device/fsl/common/tools/fsl-sdcard-partition.sh -f imx6q /dev/sdd), but also flash SD card using official prebuilt image,
my imx6-sabresd board has no any response in u-boot, I don't know why I miss something, please help me fix
this issue, thanks.
By the way, I use 8G class 10, 8G class 4, and 16G class 10 SD card to flash, then all failed....
タグ(2)
229件の閲覧回数
SergioSolis
Do you see anything in terminal window?.
Have you tried using MFGTool to flash the SD?
