No TPM information in i.MX Linux Release Note.
takayuki_ishii
Contributor V
Hello community,
I hope to know about support status of Timer/PWM module for i.MX93.
In Table 6 ofi.MX Linux Reference Manual(RM00293) has driver source code "timer-imx-tpm.c".
But no status information in i.MX Linux Release Notes(RN00210).
I would like the TPM support status to be added to the Release Notes.
Ishii.
yipingwang
  What do you mean "support status of Timer/PWM module"?
  As I know, we have two drivers for tpm module, timer-imx-tpm.c and pwm-imx-tpm.c.
  The timer-imx-tpm.c will use tpm as a timer, while pwm-imx-tpm.c will use tpm as a pwm.
  Both drivers are OK now.
  Thanks!
yipingwang
  Thanks!
takayuki_ishii
Contributor V
Hello @yipingwang ,
Thank you for your reply.
How about capture function, count between edge to edge of external input signal?
Ishii.
yipingwang
AFAIK, the capture function is not supported yet.
takayuki_ishii
Contributor V
Hello @yipingwang ,
Thank you for your quick reply.
I would like information about this support status to be included in the i.MX Linux Release Notes.
Ishii.
