No Qt platform plugin in iMX6 Yocto
2,983 次查看
gaylordlebrun
Bonjours to all,
I have crosscompile a Qt5 application on an PC ubuntu with Qt5 toolchain in QtCreator but when I want to execute him on the target (iMX6Q YOCTO), it shows:
This application failed to start because it could not find or load the Qt platform plugin "xcb".
Reinstalling the application may fix this problem.
Thank you in advance for quite answer
Gaylord
标记 (3)
1 回复
2,133 次查看
gusarambula
Hello Gaylord,
There are a couple of comments asking of a similar issue on the following community document: https://community.nxp.com/docs/DOC-328543
Although it looks like there are no platform plugins available so I would also recommend looking at the plugins path setting.
I hope this helps!
