No Display on LVDS
No Display on LVDS
1,073件の閲覧回数
VinithNama
     I'm working on IM8M MINI EVK Linux platform, we are working on integration of panasys LVDS display and we are using SN65DSI83 as an bridge converter.
I 'have applied below patch at the directory kernel-sourcr/.../git/drivers/gpu/drm/bridge.
and i have updated in my device tree file build/tmp/work-shared/imx8qmevk/kernel-source/arch/arm64/boot/dts/freescale/imx8mm-evk.dts as below
&lcdif{
 max-res = <1280>, <1024>;
 status = "okay";
&mipi_dsi {
       status = "okay";
        port@1 {
                dsim_to_sn65dsi8: endpoint {
                        remote-endpoint = <&sn65dsi83_in>;
&i2c2 {
    clock-frequency = <100000>;
    pinctrl-names = "default";
    status = "okay";
    lvds_bridge: sn65dsi83@2c {
        compatible = "ti,sn65dsi83";
       reg = <0x2c>;
        ti,dsi-lanes = <4>;
        ti,lvds-format = <2>;
        ti,lvds-bpp = <24>;
        ti,width-mm = <376>;
        ti,height-mm = <301>;
        enable-gpios = <&gpio1 14  GPIO_ACTIVE_HIGH>;
        pinctrl-0 = <&pinctrl_dsi_lvds_bridge>;
        status = "okay";
       display-timings {
            lvds {
                clock-frequency = <90000000>;
               hactive = <1280>;
                hsync-len = <54>;
                hback-porch = <75>;
                hfront-porch = <75>;
                vactive = <1024>;
                vsync-len = <10>;
                vback-porch = <10>;
                vfront-porch = <22>;
                vsync-active = <0>;
                hsync-active =<0>;
                de-active =<0>;
                pixelclk-active =<0>;
                         clock-frequency = <108000000>;
                         hactive = <1280>;
                         hsync-len = <28>;
                         hback-porch = <200>;
                         hfront-porch = <180>;
                         vactive = <1023>;
                         vsync-len = <7>;
                         vback-porch = <30>;
                         vfront-porch = <5>;
                         vsync-active = <0>;
                         hsync-active =<0>;
                         de-active =<0>;
        port {
           sn65dsi83_in: endpoint {
                remote-endpoint = <&dsim_to_sn65dsi8>;
after compiling and deploying the kernel using
bitbake -c compile -f linux-imx and bitbake -c deploy -f linux-imx then I have built entire image using bitbake imx-image-full. I cannot see any display on the LVDS ,can you help me where i was struck.
4 返答(返信)
1,060件の閲覧回数
Zhiming_Liu
Hi @VinithNama
PLS share your log
1,056件の閲覧回数
VinithNama
Hi Sir,
           Below image shows the log of my uboot.
1,051件の閲覧回数
Zhiming_Liu
Hi @VinithNama
Can you confirm that your hardware is working fine?
Try to use Oscilloscope capture the i2c wave.
964件の閲覧回数
VinithNama
Hi Sir,
 I can able to read the i2c registers and I'm getting the reset value my i2c is working but I'm not able to get any signal in oscilloscope.
