New version of Power Consumption application note for i.MX6 Quad PLUS
1,225 次查看
takayuki_ishii
Hello gusarambula
You were answered about application note of power consumption for IMX6QP.
https://community.nxp.com/message/837216?commentID=837216#comment-837216
Do you have a specific plan to release a new version of AN4509 with IMX6DP/QP?
If no, we hope to create it in this timing because
Our customers plan to update their product form IMX6D/Q to IMX6DP/QP.
In this timing, they request us about IMX6DP/QP version AN4509.
Although there are similar documents (AN5381), but we need same document
to compare between IMX6DQ and IMXDP/QP.
Ishii.
标记 (1)
1,070 次查看
gusarambula
Hello Ishii,
There is an application note (AN5381) in which the current consumption of the i.MX6QP is measured. You may find it on the following link:
https://www.nxp.com/docs/en/application-note/AN5381.pdf
It is not as detailed as AN4509 but it should serve as a guidelines for what power consumption to expect when using the i.MX6QP.
I hope this helps!
Gustavo
