Hi All,
I am using $ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.24-2.1.0.xml
From the XML file I am able to find that following URL are used:
probably you can use the command to check port.
netstat -n -o
weidong
>>About URLs in xml file
these URLs in XML file are used to download yocto reciepe.
>>How do I know which network ports are used by these URLs?
About which PORTs, we don't have related information.Are there any other URL used, if yes how to find them?
yes, after run bitabke xxx, many packages will downloaded to ../downloads directory. you can find them in related .bb files.
Have a nice day!
B.R,
weidong
