Need to interface 320x480 TFT LCD interface to imx6
3,263 次查看
titusstalin
As mentioned as a topic name, want to interface 320x480 (or 320x240) TFT LCD interface (SPI control) to imx6 sabrelite board. (custom board)
Can you please tell me how can I do this ?
Any reference driver is available and application note ?
Where is the Driver location and imx LCD display driver etc.,
It would be great if you provide for me the latest kernel version 3.14.
I just referred the imx forum links and got for very older linux kernel where we used board support files not dts support.
Titus S.
标签 (4)
6 回复数
2,150 次查看
joanxie
for low resolution, you can refer to the document as below, hope helpful for you
https://community.nxp.com/docs/DOC-172312
2,150 次查看
titusstalin
Thanks Joan for your reply.
I'm not using LVDS LCD display but RGB parallel LCD display.
Can you please tell me for this ?
2,150 次查看
joanxie
add your lcd structure in the code like board_mx6q_sabresd.c, if you use the old version, you can find it in the rpm/BUILD/linux-3.0.35/arch/arm/mach-mx6.
I also send a link to you for reference,
https://community.nxp.com/message/449105
2,151 次查看
titusstalin
Thank you very much Joan.
Any reference for dts support, as I mentioned I have also seen this link and didn't help much.
I need some reference where they have used LCDC 320x240  (or smaller or bigger) using device tree support (dts)
Can you please help me on this ?
Thanks again.
2,151 次查看
joanxie
for yocto bsp, you can focus on the source code "arch/arm/boot/dts/imx6qdl-sabresd.dtsi"
2,151 次查看
titusstalin
