I connected 3.3V to the NVCC_PLL pin.
Will i.MX6ULL work?
Could you tell me the meaning of NVCC?
best regard.
i.MX 6ULL NVCC_PLL is internal LDO output of 1.1 V - only capacitors (1×0.22uF+1×10uF)
should be connected with it. External voltage of 3.3V to the NVCC_PLL pin - definitely is not
acceptable.
Yuri.
What if I don't connect a capacitor?
Will it happen that it does not oscillate without a capacitor?
best regard
LDO outputs require some capacitors to get stable voltage.
~Yuri.
Thank you for your reply.
Does the installed capacitor act as a bypass capacitor?
best regard
yes.
