NAND disk on imx51 [WinCE]
PawelZ
Did someone used nand flash as a disk on imx51? I know about implementation of MultiNAND flash disk on imx31 but what about imx51?
PawelZ
I followed instruction to add NAND flash model and the memory is visible in eboot (flash/erase without any problems), but is not seen under WinCE. BSP_NAND_FMD=1 as well as BLOCK driver from platform\imx51-evk\drivers\block.
Any more advice?
PawelZ
Ok, so I don't know then how to mount it to see it as a partition in partition manager.
UweSteinkohl
no problem, our i.mx51 products use nand flash for image storing and data storing
what is your problem?
regards Uwe
