Multi advertisement in Android Things for i.MX7D
veli-matti_puur
I'm experimenting with Bluetooth Low energy application in Android Things. The first implementation of the application was tested in an Android phone. It works nice and smooth. The target is to get the application work in a small device running Android Things.
I installed and ran the application in Raspberry Pi 3. Turns out that there's no support for Bluetooth LE multi advertisement in Raspberry Pi.
The question: Does Android Things for i.MX7D support multi advertisement? Thus; BluetoothAdapter.isMultipleAdvertisementSupported() returns true.
BluetoothAdapter  |  Android Developers
diegoadrian
Unfortunately, we cannot tell you that since we do not support the Pico-Board. I do know that the pico-board has a WiFi-Bluetooth module. However, I cannot guarantee you if the module has support for Bluetooth LE multi advertisement. I highly recommend you to go with Technexion, they can help you with your problem.
I apologize for the inconveniences this could give you.
Diego.
