Multi OS on i.MX8M A53 core
daisukeyoshinar
Hello.
I have a question about i.MX8M Mini and Nano.
In case of Quad A53 core, can it be set as CPU Freq different every core?
Can peripherals be mapped for each A53 core?
We are considering implementing a different OS for each A53 core.
Daisuke Yoshinari
Bio_TICFSL
You should take the MX8QM or MX8QX. The hypervisor can not be used in MX8MMini or MX8MNano.
Bio_TICFSL
Hello Daisuke,
Not the MX8Mnano, You should consider MX8MQ or MX8QX for hypervisor.
daisukeyoshinar
Thank you for your reply.
I understand that it can only be used with a hypervisor.
Why do you recommend i.MX8MQ and i.MX8QX?
Is there a reason why the hypervisor cannot be used with the i.MX8M NANO Quad or i.MX8M MINI Quad ?
Daisuke Yoshinari
Bio_TICFSL
