Mounting sdcard partition of NAND
已解决
跳至解决方案
8,880 次查看
Mats1z
Dear All,
I have booted a custom board based on mx53_ARD reference board with android(R10.4 BSP). It boots from the eMMC NAND. It also have sd card slot and usb.
The various devices are mounted as follows,
NAND         -mmc0
SD Card      -mmc1
Wifi module -mmc2
The issue is when SD Card is not connected , the sd card partition of NAND is detected. When SD card is connected the sdcard partition of sd card itself is displayed not that of NAND. I referred to vold.fstab but was not successful in solving the issue.
Please share your thoughts. I like to know more details  about how mounting is done.
Thank You
Mats
标签 (2)
标记 (4)
1 解答
2,837 次查看
Mats1z
Dear All,
The issue is solved.
how to mount all storage partitons correctly in android?
1.get into android shell using adb
$adb shell
$su
2.mount the system partition with read/write permission
$ mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system
3.change the permission of etc
$chmod 777 /etc
4.pull the vold.fstab to the host machine
$adb pull /etc/vold.fstab
5.edit vold.fstab to do the mounting correctly
dev_mount sdcard /mnt/sdcard auto /devices/platform/mxsdhci.2/mmc_host/mmc0
dev_mount extsd /mnt/sdcard/extsd auto /devices/platform/mxsdhci.0/mmc_host/mmc1
dev_mount udisk /mnt/sdcard/udisk auto /devices/platform/fsl-ehci.1/usb
Now I can access the internal memory, external sdcard and usb storage from my device.
Thank You
Mats
在原帖中查看解决方案
1 回复
2,838 次查看
Mats1z
Dear All,
$adb shell
$su
$chmod 777 /etc
Thank You
Mats
